Offline Hank1027
#1 Posted : 05 March 2019 19:11:27(UTC)
Hank1027
Hi, I do not understand the scant instructions for istalling the couplers. Does anyone have a more detailed instrution manual for doing so? Thanks for any help.
Offline DTaylor91
#2 Posted : 06 March 2019 20:53:39(UTC)
DTaylor91
The instructions are the same as the 4228 Rheingold set, as far as couplers go, so you may be able to find more photos of that to help. One thing in the manual for the 2681 set that isn't clear from the drawings is this: With the current-conducting couplers, the metal strip faces up.
Also, for the current-conducting couplers, install the coupler into one car, set the car on the track, then place the second car on the track and push them towards each other. It is usually necessary to guide the coupler into the socket on the 2nd car, and to place a finger or other object underneath the coupler as it slides in to keep it from flexing as it goes in. Make sure the coupler "clicks" into place on the 2nd car. (Do not ask me how I know to check for this Blushing ).
Good luck
thanks 2 users liked this useful post by DTaylor91
Offline Hank1027
#3 Posted : 07 March 2019 11:32:07(UTC)
Hank1027
Thank you. I will check out the Rheingold.
Offline bph
#4 Posted : 08 March 2019 18:05:48(UTC)
You can also take a look at the manual for the Orient Express 42795
https://www.maerklin.de/en/products/details/article/42795/
Offline Hank1027
#5 Posted : 08 March 2019 18:25:09(UTC)
Hank1027
Thank you very much as well!
This page was generated in 0.243 seconds.
