Offline LongHairedDavid
#1 Posted : 04 March 2019 23:13:04(UTC)
LongHairedDavid
I am thinking of getting an ECOS but have been told that it won't manage MFX+.
Can anyone tell me what I would be missing if I can't have the +?
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
#2 Posted : 04 March 2019 23:18:16(UTC)
Just the world of operation stuff.. Like running out of water or coal etc.. Otherwise, mfX+ locos work fine on an eCOS..
#3 Posted : 04 March 2019 23:35:08(UTC)
Plus gives you a different operating screen and as said above you can load with coal and water and various things.
You have a choice as to which screen you use to run the loco.
#4 Posted : 05 March 2019 13:24:10(UTC)
You do not need mfx+ for the different operating screen, you do not even need mfx for that.
#5 Posted : 05 March 2019 13:35:55(UTC)
LongHairedDavid
So, by buying safely from my local supplier - with immediate access if any problems - I lose consumables? I have been using DCC since 2006 and never used anything other than - turn sound on and off - lights - bell/whistle!
By buying in Germany - with a risk if anything goes wrong of having weeks without the controller - I get the ability to run out of coal? My layout is purposely a "train set" on a 2.2 x 0.9m board. I guess I can safely go with my local supplier (always a good thing in this internet age) and buy an ECOS?
BTW, I note that the ECOS comes with a transformer but with CS3 I have to pay £80 something extra for the privilege of getting mains power!
Long Haired David
Offline Rwill
#6 Posted : 05 March 2019 14:52:26(UTC)
Rwill
My layout is purposely a "train set" on a 2.2 x 0.9m board.!
Then why do you wish to spend £630 of your precious savings adding to your MS2 controller?
#7 Posted : 05 March 2019 15:03:16(UTC)
LongHairedDavid
Ahh. Ask someone who has 200 loks why they have so many!
I like the display. I like the ability to run two trains at once - once on the loop and one shunting - I like the ability to build routes and to link into JMRI plus I fancy going to the ESU radio throttle sometime. Also, rule one applies - it's my railway so.... - grin.
Finally, I am retired but I do programming work for an insurance company in the US. They are due to pay me at least $6,000 for some work that will be completed next week. That's a good enough reason - chuckle.
David
Long Haired David
#8 Posted : 05 March 2019 15:27:23(UTC)
Did not know the ESU had a screen for world of operation. Next thing it will be making my cuppa when running the trains.
#9 Posted : 05 March 2019 15:34:04(UTC)
David
There is a ESU forum who should be able to help you set it up although your dealer should also help.
Good luck and good running.
#10 Posted : 05 March 2019 16:02:00(UTC)
LongHairedDavid
Kevin, of Coastal DCC is an old friend so there shouldn't be any issues.
Long Haired David
Offline TEEWolf
#11 Posted : 05 March 2019 17:22:41(UTC)
David
Indeed, meanwhile it is annoying people complain in a Märklin forum about Märklin and adulate the competitor. So they shall go to the competitors communities and solve there problems. I am not interested in ESU, etc. Even to complain about prices, although I have proofen in another topic (search yourself please, because it is an ESU matter) that a CS 3 bought in Germany is cheaper as the ESU one. OK if you consider the shipping costs, it reduces down to the half of the price difference. Anyway you can say an ECoS is not cheaper as a CS 3 even considering the power supply. But this is always a personal decision and has nothing to do in a Märklin forum.
#12 Posted : 05 March 2019 18:56:54(UTC)
That is not what Tom (HO) is referring to.
The latest update for the cs2 and cs3 allows you to use the world of Operation with any loco, doesn't matter if it has mfx+, mfx, MM, or DCC. You just don't get the 'consumerables problem' with anything other than mfx+.
Offline Ove Malmström
#13 Posted : 05 March 2019 18:58:45(UTC)
Ove Malmström
If you want the ECoS, go for it.
I have heard that it is a relay good control station.
#14 Posted : 05 March 2019 21:49:14(UTC)
The loco (decoder) keeping track of run-time to enforce consumable rules to make you operate a bit more complexly by considering and doing service (like pitstops on a race track) is part of the + in the mfx+ bit. If you want that feature, you need locos with an mfx+ decoder, and a control station that understands the mfx+ protocol to be able to properly interact with the loco (as far as I know).
From the above comments it appears the 'cab view of the world' way of controlling the train is beyond the MFX+ and possible with any recently updated Central Station (and as such could also be implemented by the maker of any command station with a screen) as it appears to be protocol/decoder independent.
Offline kgsjoqvist
#15 Posted : 07 March 2019 20:50:43(UTC)
kgsjoqvist
With an mfx+ decoder the cab view is available automatically on a CS3 (or updated CS2). With the latest CS2/CS3 software you can select a cab view for each loco if you wish. But this is a feature in CS, not in ECoS.
This page was generated in 0.982 seconds.
