Offline 57vert
#1 Posted : 20 February 2019 00:09:39(UTC)
57vert
So I am putting a tunnel in my layout going to the edge of the layout, but I want to put a stone wall conforming to the curvature of the track for access. I've searched tirelessly but can never tell if the items I see are rigid or if they are a thin sheet like thing that will bend.
Any sources for a flexible wall?
Offline applor
#2 Posted : 20 February 2019 00:32:52(UTC)
applor
The hard foam walls (ie. Noch) can be bent by heating them carefully with a hot air gun.
#3 Posted : 20 February 2019 01:38:22(UTC)
the ones we use are slightly flexible foam stone walls but if you add a cardboard backing onto it, you can bent it even more.
This page was generated in 0.357 seconds.
