Joined: 04/01/2019(UTC) Posts: 344 Location: England, Ipswich
On the MS2 there are slots for 10 locos. I only have 4. Is there a way to go back when changing locos rather than having to pass over 6 empty slots before I get back to 1? |
Long Haired David AKA David Pennington A mystified Maerklin Newbie |
Use SHIFT + scroll wheel and turn it back and forth to switch between locos.
Joined: 20/01/2015(UTC) Posts: 1,204 Location: Kerikeri
Don't worry, you will eventually have at least 6 more locos. I have nearly filled every slot in my two MS2's operating through the one track box. Dereck |
Northland. NZ REMEMBER 0228 for ä |
Originally Posted by: dominator  Don't worry, you will eventually have at least 6 more locos. I have nearly filled every slot in my two MS2's operating through the one track box. Dereck Not if my wife has anything to do with it - grin. Actually, I am a "buy what I need" person so it may be a slow process. Many thanks for the help. I can't understand why i couldn't work that out for myself! |
Originally Posted by: MaerklinLife  Use SHIFT + scroll wheel and turn it back and forth to switch between locos. Thanks. That was what I wanted. Mind you, since then, I have RTFM'ed and found the relevant part. I quote from page 12: "Shift+ control knop for fast Keyboardn selection"! No wonder I missed it - grin. |
