Offline Michael4
#1 Posted : 14 February 2019 09:37:10(UTC)
Michael4
Struggling with this one a bit....its for my 'alpine' section.
Does anyone have any ideas that could improve on this? Obviously the problem is that there are no points at this tight radius...
UserPostedImageScreen Shot 2019-02-14 at 08.32.06 by dralowid, on Flickr
Thanks in advance
#2 Posted : 14 February 2019 11:38:28(UTC)
Hi Michael
Seems that you are very close to a solution these track accept some adjustments. I belive one thing is going to create problems: the two 5120 as curve-counter curve.
It is best to have a straight rail between the two to avoid coupler jamming especially when locos are in reverse (pushing the train)
Also make sure that the 5120 are on the same plan. Failure to do this caused me derailments
Offline Michael4
#3 Posted : 14 February 2019 14:15:27(UTC)
Michael4
Hi Jean,
Taking your advice it is much better! I will only be using 3000/3001 and two axle rolling stock on this line.
UserPostedImageScreen Shot 2019-02-14 at 13.12.34 by dralowid, on Flickr
Now to see if it will fit on the layout,
Michael
#4 Posted : 14 February 2019 15:18:46(UTC)
Michael,
IMO it is much better looking now and probably much safer for operation
This page was generated in 0.240 seconds.
