Offline PkMärklin
#1 Posted : 05 February 2019 21:07:10(UTC)
PkMärklin
Got de Marklin K83 perfectly working with the Ecos2. Next to this, the Sniff connection between de Ecos2 and Marklin central station (old +/- 2001) is completed. But, I can't use the Märklin keyboard. Only the leds are 'on'...What could possibly be wrong?
Cheers, Pk
#2 Posted : 06 February 2019 05:47:05(UTC)
Originally Posted by: PkMärklin Go to Quoted Post
. the Sniff connection between de Ecos2 and Marklin central station (old +/- 2001) is completed.
Marklins Central Station 60212 did not exist in 2001 - do you mean a "Control Unit" 6021 ?
Again I am guessing this is a reference to a 6040 keyboard which would normally connect to a 6021
Suggest
- check the pins, in the connector between the 6021 and the 6040, for damage.
Offline PkMärklin
#3 Posted : 06 February 2019 18:23:38(UTC)
PkMärklin
Yes, I was mistaken. Of course, it's the central unit + Control 80F
I checked now the pins of the keyboard plus the decoders - also ok.
The problem seems to be in the connection to (or in ?) the Ecos2
I'm looking for a detailed description 'how to', because the manual is not sufficient enough.
This page was generated in 0.207 seconds.
