Offline Hics
#1 Posted : 28 January 2019 12:12:22(UTC)
Hics
Hello.
I wanted to add a cabin light to two of my locos: BR245 and BR94.5. They both have an msd3 decoders. Am I right? Now, according to a manual they have 4 functions available. Question is, where are they? There is no marks on a boards. BR94.5 37168.jpgBR245 29479.jpg
Offline ktsolias
#2 Posted : 28 January 2019 14:47:46(UTC)
ktsolias
The AUX 1 is on pin 15 Cable color Br/Red
The AUX 2 is on pin 17 Cable color Br/Green
The AUX 3 is on pin 19 Cable color Br/Yellow
The AUX 4 is on pin 8 Cable color Br/White
You have to follow them on the board to see where they go and if is anything connected to them.
Some times the outputs have no any connection expect the mtc connector
Be very careful with the decoder. The 4 functions apply to the retrofit decoders, but not always for the original decoders
The best is to check the decoder with a decoder tester to see how many functions are available.
Usually all the mSD3 have 4
From the photos I can see that the motherboards are extremely simple, so the operation will be easy
You need of course a polymeter.
Costas
In the first picture I can see that the AUX 1 is connected to something (may be smoke generator - Br/Red wire???)
The AUX 2 has a solder pad just in front, Aux 3 going to the second solder pad in the series of 5 and AUX 4 has no any connection
Must be so but I can't be 100% sure just from this photo
in the second I can see that AUX 4 is going to a soldering pad but as is the picture I cant see what happen with the others
May be some better photos from 90 degree angle will help
Costas
Offline Hics
#3 Posted : 28 January 2019 15:31:43(UTC)
Hics
Thanks ktsolias. but I'm gonna bother you a little longer.
Fisrtly, are the pins in this order?
Offline ktsolias
#4 Posted : 28 January 2019 17:26:47(UTC)
ktsolias
This is for Märklin
ESU (NEM) is different but the pins do the same job.
Just the numbers and colors are different
I have learn and use this one and I am happy!!!
This is coming from HGH
Costas
Offline Hics
#5 Posted : 28 January 2019 18:20:16(UTC)
Hics
Thanks ktsolias again. It starts making sens now. I will check it tonight.
Offline TEEWolf
#6 Posted : 28 January 2019 19:49:33(UTC)
Costas
You use a polymeter for what purpose, please? I know a polymeter as a small weather station only.
Offline Hics
#7 Posted : 28 January 2019 20:29:03(UTC)
Hics
I think he meant multimeter.
Offline ktsolias
#8 Posted : 28 January 2019 22:39:30(UTC)
ktsolias
Costas
Bad translation from Greek to English.....
Multimeter is a mixture of Latin -multi- and greek -meter-
This page was generated in 0.310 seconds.
