Offline bcovill
#1 Posted : 15 January 2019 18:59:33(UTC)
bcovill
Hi Folks,
Perhaps stupid question, but I didn't find any answer. Blink
I've got an mSD 60949 decoder mounted on my lok which is working fine.
Now, I'm planning to use each of the 4 auxiliary output on my decoder to drive interior lights in coaches, rear / front lights of last coach..
My thought is to replace all couplings between lok and coaches by VIESSMANN conductive 4 poles ones.
But I didn't find on my MS2 where I can activate/deactivate these auxiliary outputs? Any ideas? Must change someting in CVs? Confused
Ben
Märklin H0 - French Mountain layout in construction - MS2 Raspberry DSPi Arduino CanDIY Railuino
#2 Posted : 15 January 2019 19:10:12(UTC)
Hi, Ben!
Yes, just disable mfx in the MS2, then register the decoder with DCC and change the CVs you need.
Finally activate mfx again.
If you can get your hands on a CS2 you can use that to change the settings for the AUX outputs using mfx.
Offline bcovill
#3 Posted : 16 January 2019 06:51:47(UTC)
bcovill
Thanks Tom for your advices.
Found more detailed CV sharts for mSD decoder:
Will post an update asap.
Ben
thanks 1 user liked this useful post by bcovill
This page was generated in 0.335 seconds.
