Hello and greetings from middle of the Finland
Many of you have red my interesting adventures with CS3Plus. Now I have more to tell you:
First my broken CS3Plus. Something went totally wrong when I started to try play sounds with my two years old CS3Pls( serial 1133).
I didn't manage to play sounds from phone socket not to phones(stereo) and not to active speakers(stereo).
The I tried to put MONO-plug to that socket and something happen, I don't know what went wrong, but touch-screen didn't works after incident. Screen went black for a while and the whole screen area was quite warm, not hot though. ANd from inside I could hear something crispy sound. I terrified and take power cord off,, because I thought that something was burning.
Then I wrote to Märklin Service and ask for address to which I could send the broken device for repair. Märklin people might be busy because no one has answered to my e-mail yet.
After few days I did order a new CS3Plus from Lippe and at the same time I wrote to them also to get information what to do with that broken device. This process is ongoing still.
Today I got new CS3Plus ( version 8115) and surprise it was with latest update.
. Device out of box and a while for warmin in the inside room and then power on.
Fortunately I had latest backup from the broken device and I downloaded it to new device ( of course I did take backup from the new empty device lucky me
Because it came clear to me that my old CS3's backup cannot be used with new device. . . YES IT REALLY IS SO. The restore went OK, but information was not functional, I really don't understand why it is so but it is. One example: I could see my previous layout picture with all turnouts and contacts and so on, but restore did not bring them to the window where you can edit them. When I started to add items as they should add when they are new the hole device went crazy, Layout picture messed up and item which should be in the picture were only numbers and characters.
Then I restored the very first backup and start all from the beginning. I recorded all items, in this case turnouts first and then I draw layout picture installed one loco and tested the whole layout and turnouts. It was and is good now. Loco database was empty also, so all locos must be configured manually.
I am a bit disappointed
but then i have to think that perhaps Märklin has made better hardware this time, repaired some mistakes and this version of hardware is now good. . . . Who knows we will see.
Few words about these two devices:
There are differences,
old device at idle state without connection to layout is not very warm 38.5 degrees, power: 0.041A(Main Track) 0.036A ( Programming Track)19,1 Volts
New device at idle state without connection to layout quite warm 58 degrees all the time and power: 0.058A(Maint Track), 0.036(Programming Track) 19,3 Volts
Red buttons in new device ( two for speed) are much more sensitive that in old device.
And they are NOT COMPATIBLE WITH EACH OTHER when you think backups.
In the New Device there are still bugs inside the program, MFX-locos are not recognized as they should, I had to boot several times after it worked ok. Touch scree is not very exact even when I used mouse pointing device.
If I find interesting features or behavior during my journey to my latest Layout I will tell you later.
Jukka
Ps.
It will be very interesting to see what Märklin will tell me about broken device repairing and what they might tell me how to manage with sounds
