Offline michelvr
#1 Posted : 27 November 2018 18:28:37(UTC)
michelvr
Good Afternoon Gentlemen,
First off I would like to thank the forum members that helped me out with my new track plan.
Johnvr and dennisb thank you for reaching out to me!
This really was a labour of love for me because I wanted to use C track exclusively.
Hopefully this is as close to my final plan as can be! Please tell me what you think and if something needs tweaking.
The red colour track is level 1. Grey is the Hamburg station level 2. My rendition of John Allen’s Timesaver is green level 3. Left side of the plan is the ore mine (needs some more track) and the mountains on that side of the layout. Right side of the layout will be a two track four span bridge. The plan might need some moving on the bench but besides that Hallelujah!
Please note level 1 will also have the staging yard which presently I do not have the track for.
For the curious the small red dots indicate where I have to cut the c track to fit correctly. I successfully cut the pieces using a carbide tipped tooth saw blade in a compound mitre saw. Works very well as long as you have a clamping jig to rest the track into while cutting.
Please note the dark grey rectangles are 3 sheets of plywood.
Michel
thanks 8 users liked this useful post by michelvr
Offline Markus Schild
#2 Posted : 27 November 2018 22:06:00(UTC)
Markus Schild
Hi Michael,
Nice plan. But I see no possibility to turn around a train or a locomotive.
Markus
Offline michelvr
#3 Posted : 27 November 2018 22:33:07(UTC)
michelvr
Hi Michael,
Markus
Hi Markus,
I never thought about that and that is a very valid point! Let me correct that on my plan and I will post an update tomorrow.
Thank you for letting me know!!
Michel
Offline jcrtrains
#4 Posted : 28 November 2018 02:26:15(UTC)
jcrtrains
Looks great.
It is a bit hard to see the throat on the right. Are there double slips that allow continuous running of both tracks through the station?
#5 Posted : 28 November 2018 02:53:30(UTC)
Lots of smart thinking here- the time saver to enable operations and fiddling, but still planning a layout around that to just enjoy and watch trains circulate, be it for yourself or for visitors! So many people forget one or the other, or implement non-functional sidings
Offline michelvr
#6 Posted : 28 November 2018 04:06:14(UTC)
michelvr
Originally Posted by: jcrtrains Go to Quoted Post
Looks great.
Hi Jon,
I'll post another plan without the plywood so that you can see the right side of the station. Unfortunately Marklin doesn't make wide double slips so I just added more turnouts to get the results that I wanted.
Michel
Offline michelvr
#7 Posted : 28 November 2018 04:20:45(UTC)
michelvr
My plan to build this model railroad was to have the design on paper before I started building. Usually I build and then plan which never really worked out because I always forgot to incorporate real railroad features. Now I know what I need to do and to do it the right way! Not like before where I made changes after the track was laid.
Most times it's just me downstairs in my train room and I would like to have fun switching so that's why I incorporated the timesaver. On occasions (weekly) I'll have friends who actually miss the old layout. Now with this layout there'll be more operating interactions than watching the trains go by!
Michel
Offline Johnvr
#8 Posted : 28 November 2018 07:10:37(UTC)
Johnvr
Hello Michel,
I am looking at the gradient which you have on the two loops. In my mind, the gradient will be too steep for the trains which you plan to run.
I usually work on having about 20 sections of track to climb to the next level up in order to have a 2.5% gradient.
I am glad that you have incorporated a Timesaver, and I hope that you will be using the Marklin Uncoupler Tracks to perform this function.
Perhaps a detailed track plan of the Timesaver which you are planning would be useful, because remember also to not place an uncoupler track after a curve turnout, you should place a 064 or something between a curve turnout and an uncoupler track. This is to ensure that the wagons uncouple on a straight line.
Of course, you can also add little sidings around the layout with industries, ie logging plant, beer factory, refridgeration trucks, banana wagons, etc, so that the freighting of trucks between the Timesaver and the various Industries around the layout also becomes a feature for when your friends come to visit.
RegardsBigGrin
Offline michelvr
#9 Posted : 28 November 2018 17:06:47(UTC)
michelvr
Hello Jon (jcrtrains) & Johnvr,
Hopefully this helps to see what I have done. Once I start to lay track I will see how the elevation separation is. If I need to make changes to increase the height I will do so. I agree with adding sidings and industries it will make the railroad more like the real world. I will incorporate those after I see how everything looks.
Michel
Offline michelvr
#10 Posted : 28 November 2018 19:19:38(UTC)
michelvr
Hello Michel,
RegardsBigGrin
Hello John,
As mentioned on the other post I'll deal with the gradients once I see how everything fits in. Here's my rendition on John Allen's timesaver......
Edited by user 28 November 2018 23:40:03(UTC)  | Reason: Not specified
#11 Posted : 28 November 2018 20:48:38(UTC)
Very cool... as I was not familiar with what the "The Timesaver" was, I had to go read up on it and what it is all about. Very neat idea, and a concept I may try to fit into my layout at whichever locations I place a switching yard. For other readers who are also unfamiliar with the puzzle game that lets you try to solve the 'problem posed' in the least amount of time without derailing anything, I found this PDF that contains the layout restrictions (the length of sidings and uncoupler locations are critical to limiting what can be done where) - and the rules / how to play.
https://www.div3.ncr-nmr...ary/TimesaverContest.pdf
Offline fynrfin
#12 Posted : 21 February 2019 21:58:29(UTC)
fynrfin
This really w
Michel
Hello Michel,
Do you have a picture of the track plan, I would love to see how you built in the time saver.
Steen
Steen Jorgensen
Offline michelvr
#13 Posted : 22 February 2019 14:51:53(UTC)
michelvr
Hello Steen,
Attached below is my track plan for Hamburg. You will notice that I moved my rendition of the"The Timesaver" so that you can see it clearly.
Michel
thanks 3 users liked this useful post by michelvr
This page was generated in 0.364 seconds.
