Offline Bryan
#1 Posted : 19 November 2018 06:58:46(UTC)
Bryan
Dear All
I am converting an old Marklin 37376 BR 101 Electric to a new mSD/3 decoder. The old front LED panel has 3 LEDs in it.
The wires coming from it are ORANGE, BROWN/GREEN, YELLOW and GREY. The new mSD/3 has the corresponding wires coming from it also. Do I put a 1K resistor in line on the ORANGE lead to reduce the voltage to the LED panel as this is the return
cable I think. I have done a drawing to show what I have. Or do i put a resister in line on the BROWN/GREEN, YELLOW and GREY wires separately.
Any suggestions appreciated.
Bryan
Offline jerdenberg
#2 Posted : 19 November 2018 08:45:29(UTC)
jerdenberg
If you put a resistor in the return line only, the brightness of the LEDs will vary with the number of LEDs switched on. If you want the LEDs to have constant brightness, each LED should have its own resistor.
Jeroen
thanks 2 users liked this useful post by jerdenberg
Offline Bryan
#3 Posted : 19 November 2018 15:41:46(UTC)
Bryan
Dear Jeroen
Thank you for the reply.
Just one question, is the resistor always a 1000 ohms value when using a Marklin LED or LEDs with a Marklin decoder. With a multiple Marklin LED ( times 3) as in this case we have 1 return and 3 supply wires. Therefore each of the 3 supply cables wil have a 1000 ohm resistor in line to drop the voltage down for each LED light segment. We thus use 3 inline resistors. It is really important to get this right as if too much voltage on any of the supply wires will wreck the LED. Does anyone know the maximum voltage of a Marklin LED. Standard LEDs are about 2.2 volts I think. The supply out of the decoder is 19.2 volts.
Bryan
#4 Posted : 19 November 2018 16:09:17(UTC)
Check the resistors on the original decoder board. They might well be 2k2 (2200 ohms) or even higher.
In the 36xxx hobby locos the resistors are 5k6.
I converted some Märklin BR 101 locos to white LEDs using the spareparts from current models. I added 10k in line with the original resistor to reduce the brightness.
The board you have has 7 LEDs: three yellow LEDs in series for the main lights, two yellow LEDs in series for long distance headlights, two red LEDs in series.
1000 ohms is enough to protect the LEDs, but lights could be too bright.
Offline ktsolias
#5 Posted : 19 November 2018 18:39:32(UTC)
ktsolias
The brightness of the LEDs can be adjusted in mSD/3 decoders through programming either from CS3 or with 60971 device.
Of course the 1kΩ is absolutely necessary
Costas
Offline jerdenberg
#6 Posted : 19 November 2018 21:48:15(UTC)
jerdenberg
Costas
I can imagine it is simpler/more convenient to adjust the brightness by varying the output of the decoder, but in this case, where resistors have to be added anyway, I would leave the outputs as are, and determine the desired resistor value empirically (starting from the absolute minimum; 19.2 V with a 1k resistor would give about 17 mA through the LED, which sounds quite high/very bright to me). By using different resistors you can also give lights with different functions the corresponding brightness (I did that for the headlight vs number boards in an Alco PA).
Jeroen
thanks 1 user liked this useful post by jerdenberg
#7 Posted : 19 November 2018 23:10:17(UTC)
Jeroen
In my experience, for white LEds 17mA will be 'burn your eyes out' bright. You will definitely need to turn these down. However 17mA may be fine with red LEDs.
#8 Posted : 20 November 2018 08:28:38(UTC)
When converting BR 101s to new LED boards, I add 10k for both the white and the red LEDs.
The new red LEDs used by Märklin are much more efficient than the old ones.
I do the opposite of the conversion discussed here: I replace the LED boards while keeping the original DIP switch decoder - the decoder does not support dimming of function outputs.
In some locos where I replaced yellow LEDs with white LEDs I dimmed the function outputs to 25/255 for the headlights. But, as Jeroen wrote, when I have to add a resistor anyway, then I prefer a resistor that is closer to the required value.
This page was generated in 0.570 seconds.
