Offline ShannonN
#1 Posted : 02 November 2018 18:33:37(UTC)
ShannonN
https://www.lner.info/locos/W/w1.php
The experimental Gresley W1 No. 10000 "Hush-Hush" was the only 4-6-4 tender locomotive to run in Britain. It included a number of experimental features including a marine type water-tube boiler working at 450psi.
Although this original design is usually dismissed as a failure due to the revolutionary water-tube boiler, No. 10000 did successfully work a number of high profile trains. No. 10000 was completely rebuilt and re-entered service in 1937 with a conventional boiler and A4-style streamlining. Both before and after rebuilding, No. 10000 never carried a name, although it was often referred to as the "Hush-Hush" due to the initial secrecy of the project.
#2 Posted : 03 November 2018 11:55:04(UTC)
Yes, another interesting story!
That loco was even featured as a Meccano model back at the time!
Water tube boilers are efficient steam generators, but they work best at constant load, which is not the case of locomotives.
The biggest advantage a smoke tube boiler of the Stephenson type is the large amount of power reserves contained in the tons of very hot water contained in it!
Jacques
#3 Posted : 03 November 2018 12:17:58(UTC)
In the 1980s I dabbled in OO white-metal loco kits, specialising in the LNER. I built a J72 tank engine and a J39 tender engine before other plans got in the way and I concentrated on Marklin.
During this time I was in love with the Wills kit for the W1 "The Hush-hush". I planned to buy the kit after building a couple of other large tender engines, but never got that far! Yet another unfulfilled dream! RollEyes
This is what the built kit would have looked like:
This page was generated in 0.403 seconds.
