Offline franciscohg
#1 Posted : 25 September 2018 18:40:15(UTC)
franciscohg
Chile
Hi all.
New problem arises, suddenly my CS2 60215 sw 4.2.1 has decided that she does not want to control my turnouts anymore.
i have checked adresses and everything is ok. I am using the old decoders for C track, wich are working fine as independently tested with a MS2 and trackbox.
Made a setup with some k83 and they are not working either.
Made several resets of the CS2 and extensive messing in the config page with no results either.
Locomotives are working fine, in mfx, DCC an MM protocols.
Any clues?
Francisco
#2 Posted : 25 September 2018 20:23:15(UTC)
Is the problem with the keyboard?
#3 Posted : 25 September 2018 20:29:23(UTC)
Have you tried deleting them and setting them (or just one) with a new address.
Offline franciscohg
#4 Posted : 25 September 2018 20:52:21(UTC)
franciscohg
Chile
Hi, the on screen keyboard seems to work properly, i have changed adresses on a k83 with no results, again working fine with the MS2 and trackbox
#5 Posted : 26 September 2018 03:35:56(UTC)
- swap red/brown
- enable MM protocol
Offline franciscohg
#6 Posted : 26 September 2018 20:58:15(UTC)
franciscohg
Chile
Did all that, many times. Anyway, after reset number xxxxxxx, things are working again, uffffff. I even began to look prices for a CS3....
#7 Posted : 26 September 2018 20:59:50(UTC)
Well done. CS2 is pretty good and when Santa brings me a CS3 I will keep mine.
Glad now all OK.
This page was generated in 0.267 seconds.
