#1 Posted : 17 September 2018 18:28:27(UTC)
Has anyone tested this version and programmed m83 by configuration too?
I have version 1.3.3 with my CS3 and plan to shop now with an mfx m83.
Any tip i should now?
#2 Posted : 18 September 2018 05:40:34(UTC)
Nobody? Confused
Offline Crazy Harry
#3 Posted : 18 September 2018 19:48:28(UTC)
Crazy Harry
I think you need to use the m84 (60841 or 60842) and wire it as per your replies in this older thread: Tortoise Slow Motion Switch Machines where the m84 takes the place of the k84.
Good luck,
Harold.
#4 Posted : 18 September 2018 19:59:50(UTC)
Good luck,
Harold.
Yes i remember that topic.
To use with mfx m83 like 60832 you have to use accessory set 60821 for the turnout motor.
Offline Crazy Harry
#5 Posted : 18 September 2018 20:13:15(UTC)
Crazy Harry
Sorry, I missed the part about the 60821 adaptor piece for the m83. I read the instructions and it seems to be what you are planning is correct. Unfortunately, I do not have any experience with that configuration and cannot suggest any ideal CV values for the m83 and don't have any other tips.
Harold.
#6 Posted : 18 September 2018 20:13:57(UTC)
If i use m84 i´m pretty sure the power still remains on to the motor.
I want more safety by use m83 and pulse time until power from the m83 shuts off after switched over.
#7 Posted : 18 September 2018 20:26:03(UTC)
I missed one thing...tortoise motor safely stalls out.
So it´s okey to use m84 too.
Sorry...
Offline TEEWolf
#8 Posted : 19 September 2018 03:14:19(UTC)
Sorry...
Hello Goofy,
here you see (probabely hear it too but it is in German) the usage of a m83.
An m84 Märklin uses eg for block sections
Here you see Märklin's complete YouTube videos.
https://www.youtube.com/...UC_ulAkE0RxHUEhpvWf49pRQ
#9 Posted : 19 September 2018 05:39:20(UTC)
The videos didn´t say about turnout motors with the m83/m84.
Offline Crazy Harry
#10 Posted : 19 September 2018 18:42:24(UTC)
Crazy Harry
The Marklin videos refer to standard Marklin applications of the m83 and m84.
Turnout motors by Tortoise or others are a special case. Since the Tortoise motors Anders intends to use have stall protection the m84 can be used, the current is not shut off by the decoder, but by the turnout motor internals themselves. Alternately, the m83 can be used with the addition of the 60821 interface circuit (maybe this is just the pair of diodes for reversing operating direction of the turnout motor?). The question, I think, is: "What CV values should be used when programming the m83 for a turnout motor?" The m83 will shutoff the turnout operating current at the end of the cycle. The pulse width (operating speed) and period (operating time) CV values are what must be determined to get the desired operating speed for the turnout and to ensure that the points are thrown to the required limits. Unfortunately, the 60821 instruction sheet only suggests to use the m83 in switching function 17 (where the period CV yields the minimum switching time), but does not give any hints on ideal values for pulse width and period. I think these last two values will have to be determined by trial and error. Since there is a lack of response to Anders' request, it seems noone has done this. Therefore, Anders, you must do it yourself and please share your results for future reference.
Caution! I do not have experience in this specific application. I am only describing what I understand from reading the various manuals.
For reference sake, for those who are not familiar with Tortoise motors, here is their instruction sheet: Tortoise Slow Motion Turnout Motor
Harold.
thanks 3 users liked this useful post by Crazy Harry
#11 Posted : 19 September 2018 18:52:51(UTC)
Harold has right!
In fact does m84 do better choice by save money instead of one m83 and the accessory set 60821.
I decides to buy an mfx m84.
Offline TEEWolf
#12 Posted : 19 September 2018 20:06:26(UTC)
Hello Goofy,
since @Harry has set up this link to the Tortoise motor, I had no idea about such a motor. I only know that the switching speed is set up by the decoder. From Märklin I only know one turnout motor (for C-track) 74491. But Viessmann has a special motor including decoder for a very slow turnout switch. Here is a video (at 02:08 you see the shifting speed at the turnout)
Do you remember the series about the new Märklin decoders m83 and m84 in the Märklin Magazines 2013/2014?
https://www.maerklin.de/...men-specials-und-serien/
(scroll down to "Next Generation") Series 3
https://www.maerklin.de/...3_Digital_MM_2014_02.pdf
and 5
https://www.maerklin.de/...5_Digital_MM_2014_04.pdf
shall be of particular interest to you.
In part #3 page 27 following (02/2014 MM) is a description of the difference between a m83 and m84.
"Kleine, aber feine Unterscheidungen
Wo ist denn nun der Unterschied zu einem Decoder m84, wenn
jetzt auch der Decoder m83 Dauerströme schalten kann? ..."
"small, but fine distinctions
Where is the difference to a decoder m84, when
now the decoder m83 can switch continuous currents? ..."
Perhaps it helps.
#13 Posted : 20 September 2018 07:27:57(UTC)
I did ordered one mfx m84. I report later in another topic.
This page was generated in 0.397 seconds.
