Offline Ivan
#1 Posted : 02 September 2018 19:12:33(UTC)
Ivan
Which connecting track fits, i.e. corresponds with bent track 5120 ?
I mean, one of 5120 in the layout is to be replaced with connecting track (Anschlußgleis gebogen) of the same radius as 5120.
What`s Marklin`s number for it ?
Thank you
Offline stockerta
#2 Posted : 02 September 2018 20:11:35(UTC)
stockerta
Hungary
I don't think there is one made by Märklin, looking at a catalog I have ('89/90).
Offline Markus Schild
#3 Posted : 02 September 2018 22:46:27(UTC)
Markus Schild
Hi Ivan,
Such a rail was never offered. You can either solder a wire to the connection plate or use the cable #5004. That's a cable with a connection plate which can be installed between two rails.
Markus
Offline Ivan
#4 Posted : 02 September 2018 22:57:22(UTC)
Ivan
Hi, Markus
You are always so helpful.
Stopped searching and will solder connections to spare 5120.
Thank you very much.
MfG Ivan
Offline HO Collector
#5 Posted : 05 September 2018 19:48:39(UTC)
HO Collector
If you mean the smaller radius track with the feed wires then I should have some. Send me your address and I will post it over. Mind that it will take time as most of my collection is berried in 6 large card boxes so I will need to find the correct box.
Offline Ivan
#6 Posted : 05 September 2018 20:08:27(UTC)
Ivan
Hi HO Collector,
Very kind of you.Have already soldered connecting wires to one spare 5120.
Thank you for being kind to me.
Ivan
This page was generated in 0.247 seconds.
