Offline GlennM
#1 Posted : 22 June 2018 12:22:38(UTC)
GlennM
I was watching an MRR video on Youtube this morning when an advert appeared for this Dust Cleaning Sweeper;
https://smartocity.com/p...ts/dust-cleaning-sweeper
If it works it could be a useful layout cleaning device for cleaning areas around trees, stations, buildings, etc. and I was wondering if anyone have any knowledge of this product and how good it is. My experience of such small devices is they generally lack sufficient suction to remove the typical debris found on layouts and will only remove the smallest and lightest of common dust.
BR
thanks 6 users liked this useful post by GlennM
Offline petestra
#2 Posted : 22 June 2018 12:54:20(UTC)
Hi Glenn. Yes, I just ordered one. It connects to regular vacuum attachment hose. For 15 bucks it's worth a try. They must be pretty good as mine is on backorder.
I will review it when it arrives. Cheers, Peter. BigGrin
thanks 5 users liked this useful post by petestra
Offline GlennM
#3 Posted : 22 June 2018 13:07:55(UTC)
GlennM
That would be great Peter ThumpUp ThumpUp
#4 Posted : 22 June 2018 17:15:40(UTC)
Thanks Peter! I'm curious as well...
#5 Posted : 22 June 2018 17:40:46(UTC)
Did Glenn scroll further down the page?
Offline petestra
#6 Posted : 22 June 2018 18:14:06(UTC)
Cheers, guys.
It was scanned leaving China (what else is new?) last night! BigGrin Peter.
Offline GlennM
#7 Posted : 22 June 2018 23:18:05(UTC)
GlennM
Ahhh non-stick BBQ.................................takes the fun out of it BigGrin BigGrin BigGrin
#8 Posted : 23 June 2018 05:41:51(UTC)
I've noticed both of them. it should do well if it is attached to your own vacuum cleaner it depends on the suction capability, a 2000 Watt motor should do the job efficiently.
#9 Posted : 24 June 2018 02:12:04(UTC)
search wish.com for "Multifunction Dust Vacuum Cleaner Household Straw Tubes Dust Cleaning Remover Tool"
$3 plus $3 shipping
looks similar.
#10 Posted : 25 June 2018 20:53:03(UTC)
BR
I also saw that youtube video advert. You can get the same thing from amazon for a fraction of what they are selling it for ( https://www.amazon.com/s...rds=vaccuum+dust+cleaner )
The tricky bit, from my looking at the various models, is matching the device to your vacuum cleaner hose, depending on its interior or exterior diameter.
For example for my vaccum, I couldn't find a supported diameter even with the adapters, and that the particular product here doesn't go into the critical dimension at all on the web page is what sent me to Amazon in the first place.
On its surface, if you can get it attached properly to your vacuum's hose, it should work great.
Offline dickinsonj
#11 Posted : 26 June 2018 01:23:34(UTC)
I have made cheap and easy adaptors for various tubing and hoses by using different schedules and diameters of leftover pipes. I have often found a size that makes the size transition without any modification. In a few cases I have had to sand the outside of my adapter or shim it with something like duck tape.
It seems to have the potential to be used on locos and coaches without sucking all of the small plastic bits off. I have a bagless vacuum that I use on my layout and almost every time I empty it I discover some new surprise! It makes for a good mental exercise as you figure out which of your models has shed the latest piece. BigGrin
I am fairly sure that I will try one of these also, and as with everything else, the best deals come from Amazon - go figure.
Offline Danlake
#12 Posted : 26 June 2018 02:28:13(UTC)
Danlake
Reading the reviews on Amazon all of them (both positive and negative) talks about stiff bristle (straw like tubes), so I doubt it would be too useful unless they are extremely flexible and can wrap around our delicate models and landscape details. But will be interesting to see the reviews from here.
I use a soft small brush in one hand and vacuum tube in other when dusting my buildings and roads etc.
Best Regards
Lasse
thanks 3 users liked this useful post by Danlake
Offline petestra
#13 Posted : 28 June 2018 15:30:40(UTC)
Well, here's my 2 cents worth. Mine arrived yesterday from China. Peter. Cool
I just vacuumed the forward Schwarzburg station of my layout, both station platforms and track and I must say I'm quite satisfied with this product. True, the
vacuum tubes are quite stiff but they did a good job picking up dust, bits of fluff and grass etc. and they got around the catenary and other obstacles well.
I also did the brewery which needed a good dusting.
thanks 9 users liked this useful post by petestra
Offline GlennM
#14 Posted : 29 June 2018 12:44:26(UTC)
GlennM
Thanks Peter ThumpUp ThumpUp
#15 Posted : 29 June 2018 17:15:42(UTC)
Nice! Is it just me or do those individual tubes still look huge?
Offline petestra
#16 Posted : 29 June 2018 17:26:41(UTC)
Hi, John. Yes, they look big in the photo but they are only 2mm wide. Peter BigGrin
Offline Danlake
#17 Posted : 30 June 2018 09:13:57(UTC)
Danlake
And this is how the pro does itBigGrin
Interesting with using steam to clean trees?
Also curious if anyone has used the swifter duster as used in video?
Sorry to hijack tread, but just stumbled across on the video and thought it might be relevant.
Best Regards
Lasse
Offline petestra
#18 Posted : 30 June 2018 11:39:27(UTC)
Hi Lasse. I use the swifter all the time but it does get caught onto pointy edges. I use it mainly on the controls. It's great for general housecleaning.
Peter. Cool
#19 Posted : 03 July 2018 23:06:07(UTC)
Yeah, saw that wunderlandians video of MiWuLa. The steam is used on the forest areas to get the dust to clump, so that later when it dries it can be vacuumed up, I presume.
If I remember right, with him working the night shift, he cleans each area every several months?
Offline marklinuser
#20 Posted : 01 October 2018 05:36:48(UTC)
marklinuser
It's a nice tool, but honestly, the dust can be removed by the vacuum cleaner with a proper nozzle, at least this works for me
thanks 1 user liked this useful post by marklinuser
Offline TEEWolf
#21 Posted : 02 October 2018 21:43:13(UTC)
Isn't it very expensive? I bought a very soft make-up brush like this one
https://www.eyecare.fr/e...es/57-blusher-brush.html
Really soft, smooth and thoroughly. I use it especially for the top of an e-loco. At a regular wagon I dust (that is what my dictionary is saying - shouldn't the word not "dedusting"?) with various sizes of soft paint-brushes.
OK this "blusher brust" was a special offer, I bought for 2 €.
#22 Posted : 02 October 2018 22:49:42(UTC)
The attachment can be had for $5-10 on Amazon. The benefit of that vacuum cleaner attachment is that you can use it to vacuum up the dust that comes loose from your dusting, and is on the scenery and layout flat spaces with a much smaller risk of vacuuming up a small part that might be lying on the layout such as a preiser figure, something that fell off of a wagon or loco or some part from a model. With a traditional vacuum brush, the opening is one much larger one that sucks up a everything smaller than 3-4 cm. The attachment is not for use in wiping the dust from the surfaces as you would do with soft brushes, but more for pulling up the loose dust once you have brushed things off, to suck the dust from the ground, grass, hillsides, around trees and streets - and not also suck up the people, cars, couplings, street lights, road signs, cows, and bits that fell off the trains.
https://www.amazon.com/s...3487&rnid=2941120011
This page was generated in 0.934 seconds.
