Offline dominator
#1 Posted : 08 June 2018 23:41:04(UTC)
dominator
Following on from my thread on the sound decoder/speaker problem, I have ordered a genuine ESU 100 Ohm X 0.5 watt speaker for my BR64.BigGrinWoot Just to check I asked my Chinese supplier if they sold the same, and was told no.Huh
I spoke to a friend about it and he made this comment in jest.
"Now we know why Marklin has no 100 Ohm speakers.. The Chinese do not sell them any more either."
Now I am pretty ignorant when it come to electric theory, but I understand why you transmit power on the national grid at very high voltages because that reduces the amperage, so smaller wires can be used.
SO!
What are the advantages and or disadvantages of the 100 ohm speaker against say the 8 ohm speaker [ and vise versa ] with reference to Marklin sound in its engines?
DereckConfused Unsure
Edited by moderator 12 June 2018 06:44:25(UTC)  | Reason: Took pity on the poster.. ;-)
#2 Posted : 09 June 2018 07:55:49(UTC)
Do we need all capitals in the heading? - IT'S A BIT LIKE SHOUTING AT EVERYONE!
Why 8 ohms rather than 100 ohms? An 8 ohm speaker load requires much less power to drive than a 100 ohm speaker load to get the equivalent sound level, so that simplifies the audio output stage on a decoder.
Plus, it's not only Marklin who have switched, ESU have as well.
Offline tiono
#3 Posted : 10 June 2018 05:01:46(UTC)
tiono
As far as I know, the usage of 8 or 100 ohm loudspeaker is just to follow the industry's trend due to design constraint.
Before the availability of class-D amplifier (digital or PWM amplifier), Marklin used 8 ohm loudspeaker driven by class-AB (linear) amplifier chip. (e.g.: Marklin #29855, #34664, #37743, etc)
Then during 2000s era, power efficient digital amplifier (class-D) became popular in small devices and small class-D amplifier chip was commercially available. However, during that era, all digital amplifier require low-pass filter consisting of inductor and capacitor. This filter will be larger (and more expensive) whenever the loudspeaker's impedance is lower, thus designers of small devices opted to use high impedance loudspeaker such as the 100 ohm.
As technology keep progressing, filterless class-D amplifier became possible by the mid of last decade. Thus designers have the option to use low impedance loudspeaker ( 8 ohm or even 4 ohm). Lower impedance loudspeaker require lower voltage to generate the same output power as compared to the higher impedance. This is a boon to battery powered devices (which usually use 3.7V battery). Therefore most filterless amplifier chips were designed to handle low impedance loudspeaker, and operate at low voltage. The high impedance amplifier chip become more expensive as its market decrease
Although the locomotive is not battery powered, but the size of decoder is small, thus the designer will be happy to eliminate the L-C filter by using widely available (and cheap) filterless amplifier chip.
thanks 7 users liked this useful post by tiono
#4 Posted : 10 June 2018 11:23:16(UTC)
Another reason for the trend to 8 ohm speakers is that they are more rugged. To make a 100 ohm speaker very fine wire is used which is fragile (witness the number of 100 ohm speakers that failed in the early days of Marklin using the ESU mfx decoders). 8 ohm speakers use a heavier gauge of wire which is more rugged, so less problems with wire breakage.
Offline dominator
#5 Posted : 11 June 2018 23:07:21(UTC)
dominator
I wonder if there is any way to adapt the 8 ohm speakers. I did read that when putting resistors in circuit, the speakers dont operate correctly, as well as the resistors generate heat. What do we do when we cant get the 100ohm speakers or when they be come more expensive than the value of the loco? Eg $15.00 each from a NZ supplier and 21 Euro from Marklin, as they are now.
Dereck
Offline dominator
#6 Posted : 11 June 2018 23:09:49(UTC)
dominator
Wouldnt have a clue how to change the header BD. Not intentional, but it takes ages for me to write these posts so sometimes give up and leave the errors fro correction later.
#7 Posted : 11 June 2018 23:29:05(UTC)
Dereck
You would need a transformer to match the 8 ohm speaker to the 100 ohms the decoder is expecting. You would be better off replacing the decoder for one that will drive an 8 ohm speaker ... OhMyGod RollEyes
This page was generated in 0.331 seconds.
