Offline Torstein
#1 Posted : 01 June 2018 13:43:23(UTC)
Torstein
Hi - please help me with this problem.
I have installed a Loksound v4.0 54400 DCC in a Marklin loc BR 85 and it run perfect on the layout but when it stop, it jump in the running direction. Not always but most of the time. I can also hear the brake sound after it have stopped.
Did someone know what I have to do? Is something I have to turn off or change?
The loc run perfect with an another decoder. Controller is CS3 and the values in this are put to zero. I have tested CV 51 - 56 up and down with no result. I have read the instructions many times but not got any solutions I can find.
I have converted 6 other loc with Loksound, no problem, the only different for this loc is it have a Cube speaker from ESU.
Torstein.
Offline Danlake
#2 Posted : 01 June 2018 22:28:06(UTC)
Danlake
Hi Torstein,
I thought maybe CV 55 (inertia of motor) needs adjustment, but since you already tried that you could try to do the automatic calibration of motor?
Also double check that CV2, 5 and 6 is in correct order (start, mid and full) and by mistake not entered wrongly?
I have had something similiar when I used DCC address in the MM range, so maybe try and change loco address to something higher than 255?
Best Regards
Lasse
Offline mmervine
#3 Posted : 02 June 2018 12:26:29(UTC)
mmervine
Do you have a lok programmer or know someone who does? If so, try updating the firmware on the decoder to the latest. Also, based on the Marklin motor type, have you set all of the motor parameters correctly?
thanks 1 user liked this useful post by mmervine
Offline Torstein
#4 Posted : 02 June 2018 16:07:00(UTC)
Torstein
Hello again - it is hot outside 31C so today I spend 4 hours in first floor where its cooler, with my CS3, locomotive and programming track. I have no ESU programmer as I am a Marklin man since 1962.
Using Esu DCC decoders are only a personal taste, to try them and because M have supplied us with the correct icons for all the sounds on the function buttons. I have converted many loc with decoders over the years but I am a beginner when programming DCC decoders. Blink
First I do the what Lasse advice me, CV 2-5-6 was ok according to list. Changing address help not.
So I reset it couple of times and put it on the track for automatic calibration by CV 54 as I have tried before. The values from the test was;
Test run: CV 52 - 12 CV 53 - 47 CV54 - 31 CV 55 - 12
Esu values for M. CV 52 - 32 CV 53 - 120 CV 54 - 60 CV 55 -95
The performance was poor with jerking all the way, but it did NOT jump at the stop. So I adjusted CV 54 (K) from 31 to 15 and the jerk was nearly gone. Then I change value on CV 55 from 12 to 95.
Perfect visual running, no jerk or jumping only a long brake sound when it stop. Maybe a fine tuning later. ThumpUp
It surprise me way it are so different values for the same type of motor, but I think some CV values influents others or BR 85 have too many cog wheels.
Thank you for your input and advice gentlemen. BigGrin
Torstein
thanks 1 user liked this useful post by Torstein
#5 Posted : 04 June 2018 22:35:32(UTC)
For others not as up to speed on the details, the CVs 51-55 control the ESU decoders driving characteristics and are described, for example, in the ESU LokSound v 4 manual on pages 47, 48, 49.
Relative to slow driving behavior ESU states "Especially for the slow driving sector (speed step 1) the LokSound V4.0 with CV 51 and CV 52 to change the gain control. This helps to avoid any jerking while driving extremely slowly. However, before doing this you must make sure that there are no capacitors wired between the motor terminals and the chassis."
In the descriptions of the CV's they state:
CV 2,5,6: (pg 40) when using a 3-point speed curve -
Motor characteristic via CV 2, 5, and 6 (Fig. 25): Enter the start voltage in CV 2 and the maximum speed in CV 5. CV 6 corresponds with the speed at a medium speed step.
So its CV2 (min), CV 5 (max), CV6 (med)
(Starting at page 47)
CV 54:
Parameter „K“, stored in CV 54, influences how strongly load control will affect the driving performance. The higher the value, the more load control will respond to any changes and try to adjust the revs of the motor.
Parameter „K“ needs adjustment if the locomotive runs unevenly (jerks).
Reduce the value of CV 54 by 5 and test-run the locomotive to see if there are any improvements. Reat these steps until the locomotive runs smoothly at speed step 1.
CV 55:
Parameter „I“, stored in CV 55, provides important information to the decoder on how much inertia the motor has. Motors with large flywheels naturally have more inertia than smaller ones or coreless motors.
Adjust parameter „I“ if the locomotive jerks somewhat just before it stops or „jumps“ at lower speeds (lower third of the speed step range) or simply does not run smoothly.
Increase the value by 5 starting with the default value for motors with very small or no flywheels.
Reduce the value by 5 starting with the default value for motors with large flywheels.
Test again and repeat this procedure until you arrive at the desired result.
CV 53:
In CV 53, you set the EMF reference voltage generated by the motor at maximum revs. This parameter may have to be adapted subject to the track voltage and the efficiency of the motor.
If the locomotive reaches maximum speed when the throttle is set to about three-quarter and the top third of the throttle has no influence on the speed, then you should reduce the value of CV 53. Reduce the value by 5 – 8 and test the locomotive again. Repeat this process until the locomotive just reaches its maximum speed when the throttle is fully open.
On the other hand, if the locomotive moves too slowly at full throttle then you should increase the value of CV 53 step by step until the maximum speed is reached.
CV 52:
Together with the LokSound V4.0 decoder an additional CV 52 has been introduced which seperately determines the gain control considerably for the whole slow driving sector in speed step 1.
If you are not satisfied with the driving behaviour when the locomotive drives slowly or starts, while everthing is fine with the medium and high speed steps, you should increase the value of CV 52 by ca. 5 - 10 than the value set in CV 54.
CV 51:
Here you can adjust the inertia of the motor separately for slow speeds and starting from a stop. The desired value is to be entered into CV 51. The parameters “K slow” and “I slow” jointly influence the behaviour at speed steps 1 and 2 while the parameters CV 54 (“K) and CV 55 (“I”) are responsible for the remaining speed steps. The decoder computes a speed curve in order to avoid any abrupt changes.
thanks 4 users liked this useful post by Minok
MS2 and esu loksound v4.0M (Digital)
by Dimitris Kanellos 11/03/2016 10:13:42(UTC)
ESU Loksound v4.0 release (Digital)
by GSRR 04/02/2011 01:00:20(UTC)
This page was generated in 0.379 seconds.
