Offline Russell423
#1 Posted : 21 May 2018 03:17:52(UTC)
Russell423
I have three locos to convert over to digital. Theses will:
Two are older analogue models: EDIT:3035, 3043.
As these are to be simple conversions to digital i think i will just use the 60760 kits
The last is a newer "5 star" 3556 crocodile. This loco i would like to be fully featured. I am wondering if it would be possible to do telex couplers as well as sound. Which would the best decoder choice be for this?
It says i can program the new decoders with the 6021, is this the case? the majority of the locos i have are dip switch style encoders which seem easier to deal with.
For all three locos, is it worthwhile to go to LED lighting wherever possible? all three are using incandescent.
Edited by user 21 May 2018 20:45:15(UTC)  | Reason: wrong item number
Offline ktsolias
#2 Posted : 21 May 2018 11:06:16(UTC)
ktsolias
There are some things that you must have in mind before the decoder
1. the 3034 BR 141 is realized four times
a. 3034 (1) 1960-1968 Relais SFCM IIIE41 024 DB blau
b. 3034 (2) 1969-1975 Relais SFCM IV141 005-9 DB blau
c. 3034 (3) 1976-1980 Relais DCM IV141 015-8D Bozeanblau/beige
d.3034 (10) 1991-1997 Relais DCM IV141 278-2D Bozeanblau/beig
The data are from http://www.hfkern.gmxhome.de/
As you can see the first two versions have a SFCM motor so the 60760 set does not fit. You need a 60943 motor and an Marklin or ESU decoder
2. 3043 has a LFCM so again the 60760 does not fit. You need a 60944 motor and whatever decoder
3. The 3556 has a DCM motor so a 60941 motor is OK. Is a difficult conversion you can have an idea in my conversion of 3352 who has exactly the same frame and body
https://www.marklin-user...dile--Digital-Conversion
Costas
Offline Russell423
#3 Posted : 22 May 2018 21:06:07(UTC)
Russell423
Thanks Costas for the reply. I realize I meant the 3035 loc but I believe the case is the same, it's a lfcm motor. Can I couple the 60491 kit with the encoder from 60760? I don't need a fancy decoder for these two locs.
As for the 3556, is most of the complexity coming from the Swiss light conversion? Has anyone snuck a speaker into this loc?
Does a list of the various marklin decoders exist with their individual details? The info on the marklin site is limited as far as I can tell
Offline ktsolias
#4 Posted : 22 May 2018 23:58:32(UTC)
ktsolias
I think that 3035 has a SFCM that means 60943 motor but a foto of the inside will help a lot
As for the decoders
1. 60760 kit is coming with 60941 DCM 5pole motor, for older DCM 3pole or 5star and an fx decoder. The decoder is a very basic fx decoder with only f0 function (lights front- rear) and two hidden functions f3 ready for use and f1 TTL+ level (needs amplification) (you have to unwrap the decoder and solder wires on it etc).
In general is a cheap solution for DCM motors with poor performance in most cases.
2. Then we have the 60972 and 60982 (different connection) same without sound and f0 plus 4 AUX functions (mfx mLD3 decoders). Recommented for most of the cases and I prefer the 60972 if space is available. The base plate is very convenient and latter you can change the decoder for a better one or one with sound without any soldering.
3. Then there are the sound decoders 60975-76-77 and 60985-86-87 (mfx mSD3 decoders)
Same as the 60972 or 60982 plus sound for steam (60975-60985) diesel (60976-60986) or electric (60977-6978) locos.
the sound decoders are coming with two speakers one small and another larger so they can fit in almost every locomotive.
All mLD/3 and mSD/3 decoders can be reprogrammed with more functions or other specific sounds with the use of CS2 or CS3 or the 60971 programming tool. (Are complicated procedures but can be done)
For locomotives like 3556 croco I think that you have only one choice the mfx with or without sound for the others again you can use the fx decoder from 60760 but you have again to buy the motor (60943 or 60944) so the is better and cheaper to use the combination of the appropriate motor and and mfx decoder
Hope that you are not very confused and if it is your first conversion my advice is to start with 3035 or 3043 and not with the more expensive and beautiful 3556
Costas
Offline Russell423
#5 Posted : 23 May 2018 02:03:09(UTC)
Russell423
Costas thanks for the breakdown, everything is making sense. Great to have this list as like I said I could only identify 50% of them on Marklin's website.
I will grab a picture but I think you are correct, SFCM. some info here http://www.marklinfan.net/3035e.htm and http://www.maerklin-samm...iven/03035/03035_m_m.htm
Which seem to suggest mine is the first revision of the model and the first revision is SFCM.
1. 60760 kit is coming with 60941 DCM 5pole motor, for older DCM 3pole or 5star and an fx decoder...
Are u suggesting the whole kit is poor performance or just the motor or the decoder? I was hoping to use this basic decoder (purchased on its own) with appropriate motor kits to do the two older locos.
Offline Russell423
#6 Posted : 23 May 2018 02:05:01(UTC)
Russell423
One more question: other than additional function outputs on the fx decoders do they have any benifits over the decoder from 60760?
Offline Russell423
#7 Posted : 23 May 2018 02:19:39(UTC)
Russell423
Final final question. I only have the 6021 for programming decoders, will this be a hindrance? Will I need the programmer to work with the newer decoders. All my locos have older, dip switch style decodees with potentiometers to control max speed and axcel/decel
Offline ktsolias
#8 Posted : 23 May 2018 06:50:11(UTC)
ktsolias
The 3035 has an SFCM
The motor in the 60760 kit is actually the 60941 and is OK
The decoder in the 60760 is not available separately, is an fx basic one and has poor performance but any way does not fill your needs.
The 6021 can not do function mapping or sounds modifications
I suggest that you must put targets what exactly wants to do with each loco, what is your budget, then we can have a better discussion.
If you have only old deep switch decoders the performance of those varies depending of the type (6080, 6090, 6090x etc)
Costas
#9 Posted : 23 May 2018 09:02:38(UTC)
I updated my 3034 E41 from the year 1961 with 60943 motor and 60947 decoder.She is running like a dream even she is 57 years old today.ThumpUp
#10 Posted : 23 May 2018 11:00:14(UTC)
I converted my 3034 of similar vintage with a Lokpilot V3 and Hamo magnet. It also runs very sweetly!
BTW my 3035 FS E424 came with a DCM motor not a SFCM. One should always check physically before ordering the wrong motor kit!
Offline Russell423
#11 Posted : 23 May 2018 19:50:42(UTC)
Russell423
Thanks everyone for the insights.
Costas, (or anyone for that matter) what are the issues with the 60760 decoder other than it has limited function outputs (seems like it's limited to just directional lighting)?
Offline Donb
#12 Posted : 23 May 2018 23:35:11(UTC)
Donb
I have the 3556 and had Walter at Eurorail Hobbies do the Digital conversion with sound last year. He used a ESU V3 sound decoder. It works very nicely except the Swiss headlight function does not work. Apparently if you can fit an ESU V4 decoder in there, there is a way to utilize one of the aux wires to enable the Swiss headlight function, also with adjusting a few CV's.
Best Regards,
Don
IB 2 and MFU modul, C track and Z scale, mostly DB/DR and SBB, SJ
#13 Posted : 24 May 2018 16:10:47(UTC)
There are no real issues but you must realise that it is a basic decoder. There are not many possibilities for adjusting CVs, and function outputs are limited (There are two extra functions available if you don't mind a bit of soldering).
One of the more apparent limitations are the reduced number of speed steps (14?) which means that as you turn the throttle up or down you will see the speed change visibly in steps. I adjust my acceleration/braking delay to a higher than normal value so that the steps are not so noticeable.
To put the decoder in relative performance terms, I would say it is a bit short of the standard of a 60902 decoder or the newer mLd3, but miles ahead of a Delta or 6080 decoder.
Offline Joe Meiring
#14 Posted : 24 May 2018 21:29:21(UTC)
Joe Meiring
Thanx Ray! I fitted the 60760 in my very old 70's br24 about 6 years ago and never thought of adjusting the acc and dec to minimize the obvious steps in speed. Works a treat! Thanks SO much 👍🏻
Joe
Medium digital C track layout with MS2: When I grow up I want to be a steam engine driver....
thanks 2 users liked this useful post by Joe Meiring
#15 Posted : 25 May 2018 04:52:46(UTC)
I've done several conversions (Swiss Crocs).
using an ESU lokpilot or sound decoder you are able to use 4 digital code numbers (sound decoder), e.g. 56, 57, 58, 59 with your 6021 giving you 16 sound functions. yes you could use a telex coupling and yes you could install a sound decoder.
the ESU sound decoder would allow you with an ESU 21 pin adapter plate to use 6 Aux functions. this also would allow you for instance the use of Led's for your Swiss light change overs on your crocodile.
your 3-1 light change is simple by adding one direction diodes, (F0), Aux 1 = telex coupling front, Aux 2 = telex coupling rear, Aux 3 = marker light front, Aux 4 = marker light rear, Aux 5 = interior cab light,
smd led's would be the way to go as they do not require a lot of space., Märklin has a circuit board for later released crocs which could be used if you are prepared to pay the price for it.
regards.,
Offline Russell423
#16 Posted : 25 May 2018 05:25:08(UTC)
Russell423
thanks John for the tips.
Am i able to fully set up the decoder like you say (using multiple addresses etc) with just a 6021 or do i need a more advanced controller/the USB programmer?
I'm good with small electronics and soldering so i should be able to handle the LED conversion if I choose too. It seems like there is enough room for something larger than a surface mount LED in the 3556.
Does a pinned daughter board style decoder fit in a 3556? maybe only in the Cab? It seems like the typical installation location is in under the one hood.
#17 Posted : 25 May 2018 13:53:05(UTC)
Russel, all you need is a 6021, set up the decoder with 4 addresses., I think you mean USB programmer = an ESU Lok programmer
it is always difficult to advice train enthusiasts when it comes to electronic components such as decoders and control units.
for some people the CS is suitable and for others (like myself) whereas some tinkering with the programming is involved I've chosen the ECoS and ESU decoders.
buying an ESU sound decoder it is always recommendable also to include a lok programmer and programming is made 100 % easier, to adjust the CV's manually it would be a nightmare for me and as one has a large collection of locos, the lok programmer serves this task wonderfully.
it is with the lok programmer you can activate the 4 decoder addresses and many other functions.
it is always a good idea to choose which control system you're going to use and this should be done before you invest into a system you later may regret but this depends what you've got in mind.
it served well for my applications especially all my older locos being converted with a 5 pole high efficiency motor with ball bearings and an ESU decoder but it is your choice and I'm not here to recommend one or the other.
in my opinion it would be silly to buy the latest Märklin loco and refit it with an other brand decoder and I wouldn't recommend to buy a lok programmer just for one loco.
I'm also not familiar with Märklin sound decoders and their compatibility with the 6021 whether or not you can activate 4 addresses.
regards.,
This page was generated in 1.335 seconds.
