Offline frickwg
#1 Posted : 17 May 2018 00:42:16(UTC)
frickwg
Help finding the right coupler, Marklin Swiss Ae 6/6 #11414
I have a Marklin, Swiss, Ae 6/6, #11414, green, Stadt loco “Bern” that needs a new coupler. I >>think<< (as I bought it used) that it was once the analog version (3337), but it could have be the digital versions (3737) and it looks like it was converted again to a newer chip.
I can’t seem to find am exploded drawing showing the part numbers, including the couplers. I have the exploded drawing for 3332, 3350 and 2560 which looks similar, but the couplers, 217080, are not even close.
Can anyone help?
Other info: Labeled on the truck, “Made is Western Germany,” E10311672”
Willis.frick@cox.net
#2 Posted : 17 May 2018 01:42:25(UTC)
If your model looks like this:
http://www.hr4920.de/Web...D/8962/6C05/L1880581.JPG
It is a 3050
http://www.hr4920.de/Web...D/8964/1C34/L2330844.JPG
It is a 3338 or 3638. (3337/3737 was a different model of the same locomotive type).
The difference between the two models is that one is a slightly overscale version that dates back to the 1960s and the second one is a new version that is exact scale length and dates from 1992.
The 3050 is slightly oversized in width and reduced in scale length. The 3338 is more protypical in scale width and length.
The easy way to tell which one you have is to look at the assembly in the bogie area. On the 3050, this section is molded into the shell, whereas on the newer 3338, it is molded in plastic and is part of the bogie assembly. The 3050 also has dual headlights (one red non functional) between the front windows, the 3338 has a single white light at the same place.
3050: Coupler 217080 https://www.ebay.de/itm/...Ersatzteil/362315571695?
For the 3338, the parts should normally be the same as all subsequent models: https://www.maerklin.de/...lnummer=37361&lang=2
Coupler Pocket: E274670 https://www.ebay.de/itm/...UPPLUNG-SC/292518108586?
Coupler: 7203 aka E701630
3050:
https://www.lokmuseum.de...SBB&Seite=2&SID=
https://www.lokmuseum.de...ahr=-1&bisbaujahr=-1
#3 Posted : 17 May 2018 14:18:23(UTC)
Is the ”E10311672” a stick on label? If so then it left the factory as a digital locomotive.
Offline frickwg
#4 Posted : 17 May 2018 17:04:12(UTC)
frickwg
Thanks!!! Just the exact, correct answer I expect from this board and other Marklin modlers.
THANKS>>>
It is a 3050
3050:
This page was generated in 0.291 seconds.
