General topics
H0-scale
Does anyone else run trains that need to be routed to avoid R1 curves
Joined: 15/10/2006(UTC) Posts: 2,319 Location: Washington, Pacific Northwest
Since the Märklin versions of the BR 012 (aka 01.10 oil fired) use an ancient design and make a mess of motor noise when run, I went with the Roco BR 012 (78137) that was released as a new item last year. It has a minimal curve radius of 419.6 mm, which means Märklin c-track R1 curves of 360mm are out of the question, but Märklin c-track R2 curves of 437.5mm are fine. This is my only loco restricted to not running R1.
That's all well and good but as I'm still designing my layout I in theory have the chance to make sure I'm only running R2/R3 - though so far I've planned R1/R2. So if it turns out that due to fitting the desired routes into the room most effectively still requires R1/R2 for the main line, I've been giving some thought to how to handle that.
The main line is 2 tracks that run side by side, so anywhere there as an R1 inner curve, there would be an R2 outer curve. This means for right turns, I'd need to switch the train over to the left track first, make the turn, then switch it back to the right track (as the German rail system is right hand drive). That could be accomplished by installing the appropriate turnouts before and after all bends like this (likely at tunnel entrances/exits ).
Does anyone else do this sort of thing or has addressed a similar problem?
If Märklin ever comes out with an updated full-new BR 012 I could switch to that and sell the Roco but by then even I will have built my layout I suspect, so I'll have found a solution. The intended use of the loco is as a museum train only occasionally brought out for special runs ( It will have a plinth-like existence as the 01 1102 did in Bebra, Germany, except maybe once or twice a year bring it out for special runs).
I'd not be opposed to modifying the Roco in a minor way to allowing it to run on 360mm track, but I suspect that that isn't a viable option, otherwise there would have been an option to configure it that way out of the box.
Joined: 28/11/2007(UTC) Posts: 8,226 Location: Montreal, QC
I used to have the classic R1 and R2 tracks. In the 80s, I got R4 and R5 K track, which was ok since I was using a non-permanent floor layout. I have since gotten R4 and R5 C-Track and am using that when I set up the floor layout. If you have a fixed layout, you might not be able to use larger radii. I did have a discussion with one modeller who was bemoaning his inability to use the larger radii. He explained to me that his setup was R1 and R2, but that he had straight track sections between each quarter turn. I asked him why he could not replace this with larger radii curves and omit the straight tracks. He said that this had not occurred to him and he would take a look at this possibility. Unfortunately, I have not heard back from him since that day.
The only problem with models with restricted radii is that these models might have problems over switch tracks that still use tighter radii and with S-curves.
One thing that you could consider is the have a base layout using R1 and R2 and to install a simple oval or oval with passing loop on the outside, which can be used for models that can't handle the tight radii.
In prototype, this would be akin to having a mainline which at some point would run next to a local or regional line. For example, modern ICE or TGV trains might run on a mainline, but would be less likely to be found on a regional line.
I hope that this is of use to you.
 1 user liked this useful post by mike c
Joined: 21/05/2004(UTC) Posts: 1,768 Location: Brisbane, Queensland
I designed my permanent K track layout with R3 (K track R3 = C track R2) and higher to avoid this issue. Also, smaller radii are unrealistic and don't look good anyways. I understand not everyone has a whole lot of room, though it hardly takes much more room to avoid 360mm radius.
Thankfully both Marklin K and C track standard turnouts are R3/R2 so they are not an issue. The original K track turnouts were R2 though (360mm) ie. 21xx series. Annoyingly the K track curved points are R3 to R2 and with K R2 being 360mm it rules out being able to use curved turnouts. C track now have the wide radius curved turnouts.
edit: what I am a bit annoyed about though is that a lot of locomotives requires 500mm + radius for the cylinder rod protectors. This is fine for the mainline but my branchline has the R3 424mm curves so I wont be able to use them there. |
modelling era IIIa (1951-1955) Germany |
 1 user liked this useful post by applor
I think you will find that switching tracks will clog up your mainline running considerably, since any traffic coming the other way will have to wait. In real life this is less of a problem, but in a model layout with very small distances between stations, any head-on delays such as what you describe could easily lead to gridlock, or at least everything stopped except for one train, having to switch tracks.
Furthermore you would have to start making special cases for just that loco, unless your controlling software can associate a tag with that loco ("no short radii") and then be programmed to automatically reroute around such curves. |
 1 user liked this useful post by DaleSchultz
Joined: 03/06/2013(UTC) Posts: 431 Location: Melbourne, VIC, Australia
Originally Posted by: Minok  This means for right turns, I'd need to switch the train over Well, of course you could just have only left turns  . (I realise that you've thought of this already). Can you give us an idea of your space and/or track plan ideas? I would think that if you are willing to have the BR 012 only run in one direction around the mainline, then you could just have mostly left turns (R2 on outside), and then have the occasional R2/R3 curves when you need to turn the other way, and not have the complication of switching back and forth. Also more of the joy of seeing trains pass each other on the mainline. |
- Herman |
 3 users liked this useful post by hvc
Joined: 05/12/2004(UTC) Posts: 2,976 Location: CA, USA
Did you try the Roco locomotive on R1? I've found more often than not that they run just fine on 360mm despite the catalogue saying otherwise... |
SBB Era 2-5 |
 4 users liked this useful post by 5HorizonsRR
Good point in testing it. I'm planning that with a temporary c track setup in the car coming week.
The track plan has an R1/R2 helix as it's going to be a two level that runs around the perimeter of the room on shelves making a turn around at the end stations via a loop around. While I could probably replace most of the R1 with R2 and R2 with R3 the available space in the room for walking would shrink substantially and reduce the area I could place stations in substantially as I'm intending to have 6 stations along the two levels, one at each section where there is straight running (it's complex without a picture , which I cannot provide yet).
Having everything else park when this special train runs may not be the end of the world. The helix isn't an issue but the two end turnaround loops would be the only places that would be unavoidable. I'll have to get into wintrack and see what I get by making them R2 (ctrack). Most of the tight curves are intended to be under terrain so the optics are not a critical issue for me.
Good that the turnouts are bit likely anything to worry about but my test of track will check that out as well. I'll try to post a picture from wintrack in the coming weeks for this curious. |
Joined: 16/11/2011(UTC) Posts: 5,842 Location: Hybrid Home
Originally Posted by: applor  Also, smaller radii are unrealistic ... So are most larger radii. Originally Posted by: applor  Also, smaller radii ...don't look good anyways. Depends how you use them. Agreed, a full R1 circle in full view doesn't look good. However, e.g. looking from below into the inside of a tight curve isn't necessarily unpleasant. Anyway, this doesn't matter when out of sight (viewblock, tunnel, shadow station). Originally Posted by: applor  I understand not everyone has a whole lot of room, though it hardly takes much more room to avoid 360mm radius. True. |
 3 users liked this useful post by Alsterstreek
Joined: 27/07/2009(UTC) Posts: 5,862 Location: Leesburg,VA.USA
Sadly I don't have any because my layout has way too many r1 curves and I'm not the type who would buy a Lok only to have it sit on a shelf. Peter.
 4 users liked this useful post by petestra
Originally Posted by: Alsterstreek  Originally Posted by: applor  I understand not everyone has a whole lot of room, though it hardly takes much more room to avoid 360mm radius. True. Well that depends on the room, layout plan and size of the operators. Going from an (all C track) helix of R1/R2 to R2/R3 adds 155 mm to the diameter. The Helix takes up an additional larger footprint of approx 2.5 sq-ft more. Its not a lot all on its own seemingly but if you take an isle for walking between sections and then have to make it narrower by several inches from both sides what was suddenly was easy to walk down becomes a challenge to squeeze through. What was a nice platform now has to get trimmed a few inches in length because of the approach/departure angles/curves of the track coming in around a corner. Its all a compromise in modeling, realism is right out the door for much of it; that's not so much a concern for me (I'm already planning to run only locos with 3 passenger cars on trains that normally have 7-11 cars because its more important to me to have multiple stops along then way (of short trains) than have nice long run of a more prototypical long train). |
 2 users liked this useful post by Minok
Joined: 03/04/2013(UTC) Posts: 302 Location: Fraser Valley
I had the same dilemma. I have the 241 and it requires R2 min curves. But fortunately my layout is small (4x8 double oval) so it was easy for me to change from R1/R2 to R2/R3. I added 12" to one end of the layout table (now 4x9) to make room for the larger radius lengthwise, and also allowed me to add some length to the straights. I am now quite pleased with the result. An additional benefit is that my storage sidings have more length so that they can now accommodate longer trains. I had originally built this small layout as a stepping stone to a much larger one, but after two years, I am liking it just fine. Less track to clean!
Best Regards,
Don ___________________________________________________________________________________ IB 2 and MFU modul, C track and Z scale, mostly DB/DR and SBB, SJ |
 1 user liked this useful post by Donb
Well I think this has resolved itself for the better. I set up a switch with 360mm radius R1 curve on my table to test this radius against the loco that challenge the specifications that Roco provides on it's website and in the locomotives paperwork. Let me say I'm not happy with the way Roco documents it's locomotives (beyond the radius limitations) as the documentation describing how you remove the tender from the loco does NOT describe the damn wires also connected. And the reengaging of the power contact plate and simultaneously inserting the floppy Kardan shaft all at the same time is a friggen nightmare to get done. Jeezus! Finally got it in there to then find a small spring fell out I'd the locomotive model from somewhere.  From where I have no clue because while there is a spare parts list with pictures of the parts there is no exploded diagram like Märklin and decent manufacturers provide, so there is no way to know where in the loco most of those parts are located. Never complain about Märklin documentation again. it's awesome compared to the Roco docs and it's missing data, misleading data and English misspellings and grammar problems, and squirrelly page sequences. But I finally got the loco on the straight and then ran it around the R2 that it should do, no issues. Then the R1 360mm test and... That worked without a hitch. Top speed in and reverse. No issues. So is the limitation only when there are cars attached? Or is the limitation only when one installed some of the cast number of trim bits in the box I've yet to apply? Or did this spring that fell out act as a light limiter and by bre and new now broken train as a result can now do tighter turns? I don't know. All I know is going forwards and backwards through a nearly 180 degree turn that was 360mm radius was no apparent problem. |
Joined: 15/12/2015(UTC) Posts: 523 Location: Maryland, Baltimore
Boy, I wish you had some better things to say about Roco.  I recently ordered my first one and I'm hoping it will be a winner. On watching you video you seemed to have solved the R1 operating issue. I noticed too that when you switch on the sound that it sounds somewhat better /different from the Märklin sounds that I used to hearing. At least that's something I have to look forward to.  You may want to consider contacting Roco and sending the pic you've taken of the spring with the hope that they would be able to tell you where it belongs. Chuck
 2 users liked this useful post by skeeterbuck
Joined: 27/12/2009(UTC) Posts: 106 Location: Fish Hoek, Cape Town
My observation as well Chuck- the sounds are quite different to M. I have a number of locos bought from 2012 to 2015, and they all have the same sounds😱 My v200 fitted with an ESU loksound decoder is far and away better than my standard M diesel sounds too. Let me know about your Roco purchase, am weighing up moving from M to Roco...., Joe Cape Town |
Medium digital C track layout with MS2: When I grow up I want to be a steam engine driver.... |
Originally Posted by: Joe Meiring  My observation as well Chuck- the sounds are quite different to M. I have a number of locos bought from 2012 to 2015, and they all have the same sounds😱 My v200 fitted with an ESU loksound decoder is far and away better than my standard M diesel sounds too. Let me know about your Roco purchase, am weighing up moving from M to Roco...., Joe Cape Town I plan on doing a review of it once it arrives, hopefully soon.  On Roco's site they used to show a photo of the prototype but now it's a photo of the actual model. This to me is a good sign showing that it already being produced. Here's a link: http://www.roco.cc/en/pr...-0-0-002-1/products.html
Joined: 30/08/2016(UTC) Posts: 636 Location: Brussels
I like the sound on my Roco locos too. I have a couple of Roco steamers, 78223 and 68149, for both the minimum radius recommended is 420mm but the small print says they will both run on 360mm if you do not fit the piston protection sleeves and run the loco very carefully. I have never bothered with the sleeves but both locos run just fine forward or backward at up to full speed on 360mm loops alone or pulling trains. I'm very happy with my Roco steamers and will buy more. But as Minok reports the documentation leaves much to be desired. On some dubious points I had to come here for clarification, but in all such cases Maerklin users net is your friend Jabez |
I heard that lonesome whistle blow. Hank Williams |
 2 users liked this useful post by Jabez
Originally Posted by: skeeterbuck  Boy, I wish you had some better things to say about Roco.  I recently ordered my first one and I'm hoping it will be a winner. The loco would have been fine if I'd not had to do anything other than rail it. The frustration was in the reattaching the tender to the loco because it requires inserting the shaft again and one part moves around while also aligning the electrical contacts tab into a fixed slot - and they are near the same length so you need to get both aligned at almost the same time (while the speaker wiring gets in the way). So don't take it apart or need the diagrams to figure out parts and it's great. My guess on the spring is it is to pull in the slack of the speaker wire into the cab. I'm just heasitant to try and put it back in as it would require bulling the tender off again. |
 1 user liked this useful post by Minok
Minok, have you ever worked on a Roco loco before? I know when I first started working on Märklin locos initially I found some items awkward to do but now that I'm used to disassembling them it usually goes rather smoothly. My thinking is that any production loco must be easily enough to assemble once you know the process or "secret way" to do it. For the loco to be assembled by factory workers it can't be too fiddly or it would slow production too much.
Good to hear that you were able to solve your radius problem.
Chuck
No I'd not worked with a Roco loco before. The loco tender interface is a problem though as it seems to require 3 hands and tiny fingers to get back together or some jig to hold things just right along with small tweezers (which is more like Kelly the way). A good way to hold the loco at eye level and support both the loco and tender bodies and hold them while allowing you to slide the tender towards the loco AND simultaneously manipulate the shaft and contact plate is key. If there is a secret I'd sure like to know. The spring has been identified by folks on stummi as the one in question ( see my 2018 loco arrivals post) but now it's a question of if I can get it back in without pulling the tender off again as I want to avoid that at all costs. And get as much slack of the speaker wires back into the tender. A lot of this feels like delicate surgery on a mouse. Someone in a Facebook group did warn that while the 012 may appear to run fine on 360mm radius that this could damage the connecting rods over time. As I'm not running my 012 much except for maybe annual special occasions I'm hoping not to come into any issues. |
Originally Posted by: Minok  Someone in a Facebook group did warn that while the 012 may appear to run fine on 360mm radius that this could damage the connecting rods over time. As I'm not running my 012 much except for maybe annual special occasions I'm hoping not to come into any issues.
This caution may well be true, so perhaps I should enlarge on my earlier comment. I do not have any R1 on my main lines, only in shunting yards, turntable access, etc. so my testing of the two Roco locos on an R1 loop was purely to ensure that there would be no problems when they have to negotiate such sections. I do not run them over R1 curves except in such circumstances, and my comment should be read in this light. Jabez |
General topics
H0-scale
