Offline Don Morris
#1 Posted : 19 April 2018 05:02:58(UTC)
Don Morris
Is it possible to delete layout plan pages on a CS2, tried to find something on the net, no luck.
User manual does not cover deleting.
Thanks in anticipation
Ted Morris
#2 Posted : 09 May 2018 12:14:14(UTC)
Hi Ted
Just in case you have not found how to clear the layout plans you must:
SIMPLE CASE (only one layout plan)
1- Select Layout and the tool key
2- Select the tool key (the wrench)
3- Select "New" (because you need to create one new layout before deleting the existing one
4' among the 2 layouts select your existing one and then select delete (Löschen)
COMPLEX Case (Multiple Layout plans)
3- Select each of your existing layouts and delete (eraser key) all the connections (cross references) to another layout (he arrow symbol)
4- Repeat the same on each of the layouts you have
5- Create a new {empty} layout
6- Delete each of the old/existing layouts
Example of a complex case
You may see multiple layout pages, and at the bottom the entry "Löschen "(erase) and, on the layout, the cross-references (arrow and white background) you need to erase first prior to any layout deletion.
I hope this helps
This page was generated in 0.378 seconds.
