Offline lewistrain
#1 Posted : 25 February 2018 04:40:29(UTC)
lewistrain
Hello gentleman, I have recently gotten back into Marklin and have come up against the one thing I cannot tolerate the most from model engines GEAR NOISE!
To me, there is nothing quite as annoying as a beautiful steam loco slowly traveling along a track accompanied by horrible gear whine and chatter.
Dont worry, this isnt from poor maintenance or a lack of care. its simply something that all of my nicer Marklin engines do, as well as all the better ones my friends have.
So this time i have decided to do something about it.
A little while ago i was rebuilding the diesel engine in my truck and after talking to various engine builders, decided that coating various surfaces (piston skirts,cam lobes,bearings) with PTFE/TEFLON was a good idea.
This coating has fantastic run dry and awesome run wet characteristics. so while pondering the ever present gear noise in my lovely little engines I am now going to disassemble and send off some gears from one or 2 locos and have them PTFE coated in the hope that this will reduce the horrible noises they make.
Short of having custom plastic gears made this is all i can think of.
Has anyone on here had any experience with similar things?
LOLOLOL they are just toys, grow up and play with them.
thanks 4 users liked this useful post by lewistrain
#2 Posted : 25 February 2018 05:57:49(UTC)
I've come up with some ideas but nothing like getting rid of the general noise. Märklin has tried to overcome that noise with adding a plastic cog gear between 2 metal gears, but there is also noise coming from the rod mechanism, my answer to reduce noise was to install ball bearings on both sides of the armature shaft and also with the 3 or 5 pole motor (drum armature) I have corrected the line up between brush holder (both sides) and the armature to a true 90° angle it reduced the noise but didn't get rid of., mind you there isn't any oil or grease within the gears
Offline Michael4
#3 Posted : 25 February 2018 10:24:44(UTC)
Michael4
I too have been wondering about noise. I run some old locos that can get very noisy either from armature shaft or gears. I find that if I clean the bearings of the shaft and the gears then re-lubricate with a fine oil they will run very quietly and smoothly but after a few hours use the noises start to return, most often from the armature shaft and it is amplified by the metal bodies. The locos in question are 3011/3013/3014.
For the gears I had thought about trying one of those dry lubricants that come in a spray, I think they are silicone, possibly ptfe. I have also pondered a dab of mos2 (molybendum disulphide, the stuff you pour into noisy gearboxes!). It is said to work by coating the bearing surfaces over time.
For the armature shaft I'm not sure. Is the rapid return of the noise due to wear? Should I use a thicker oil? Does the shaft wear first or the bearings? It would be easy to replace worn armatures but the 'back' bearing is often integral with the chassis and presents a problem.
Any suggestions welcome. Right now turning my hearing aid off is the best solution!
thanks 3 users liked this useful post by Michael4
Offline Br502362
#4 Posted : 25 February 2018 15:52:42(UTC)
Br502362
If you are going to use MoS2 I suggest that you try this: Red Line CV-2
It contains red molybden which in better than the black one.
Åke
Offline lewistrain
#5 Posted : 26 February 2018 00:47:41(UTC)
lewistrain
Hello John, I think I saw the ball bearing mod in another post, did it reduce the ticking/grinding noise they make at slow running?
the rod mechanism noise isnt a problem for me, i have my dads old hornby 3 rail and the rod noises on that old stuff is actually quite nice, same as my vintage fleischmanns.
Its that damn crunching grinding ticking sound marklin motors and gearboxes make that sends me mad.
do you know the ball bearing size off the top of your head?
Offline Michael4
#6 Posted : 26 February 2018 12:52:56(UTC)
Michael4
Åke
Ake,
Interesting, I could use the rest on my Austin 7. Did MoS2 make any difference or did it just make a mess?!
Offline Br502362
#7 Posted : 26 February 2018 13:01:13(UTC)
Br502362
Åke
Ake,
Haven't tried it on locomotives yet. But it works fine on other locations where MoS2 is used.
My quess is massive mess if used too much. A thin coating should be enough. I must test it on
a 3000 steamer.
Åke
Offline nzr1
#8 Posted : 26 February 2018 15:19:03(UTC)
nzr1
I have managed to get steel and brass worm wheel gears to run much more quietly with the following method but have not tried it on spur gears. So for those who wish to experiment this is a suggestion and a starting point not a step by step cure.
If you want to try it then I recommend that you experiment on a low value "junk box loco" before trying it on anything more valuable.
1. Dismantle the locomotive and remove the drive rods.
2. clean any and all grease or oil from the gears. (Use a solvent like WD40, gasoline, lighter fluid or similar but be careful. You don't want to strip the paint on the chassis)
If the gears are tight smear a small amount of valve grinding paste on the gear teeth and run the motor for 5 - 10 minutes in each direction. Clean the valve paste off the gears. Something like denatured alcohol or contact cleaner works well. If the gears are not tight don't use grinding paste go straight to step 2.
3 Redo above but this time use toothpaste instead of valve grinding paste. Clean thoroughly.
4. Redo again this time with metal polish.
5. Thoroughly clean the gears and surrounding areas.
6. Lubricate with the appropriate grease or lubricant.
This method needs constant vigilance. The aim is to bed the gears in and take off any rough surfaces not wear them out prematurely.
I use good quality clock oil for rods and shafts.
For gears I generally use chain bar oil designed for chain saws. Chain bar oil is designed to be thin enough not to clog up the chain but has an additive that helps it stay where needed and not get thrown off by centrifugal force.
From what I recall of the chemistry of it is that the oil is in long strands and the adhesive properties are physical rather than chemical but I am going from memory so maybe well off the mark.
I am aware that there are many new high quality lubricants no the market so others with more experience of them may light to make suggestions. I am just going on what has worked for me till now.
Pete
Anyway these are just a few things to ponder and maybe try out
thanks 5 users liked this useful post by nzr1
Offline Michael4
#9 Posted : 26 February 2018 16:59:30(UTC)
Michael4
That poor old 3000 won't know what's hit it!
Offline lewistrain
#10 Posted : 05 March 2018 09:22:31(UTC)
lewistrain
Ok.....so I got the gears back from the coating place, a bit upset, I didnt realise the wheels were made of some kind of low melting point alloy, and so the 2 drive wheels I left on the axles with the gears have flattened and melted a bit. I was still able to do a quick test run but the poor E40 is a bit wobbly with 2 wheels in such a state. I deffinatley would say the teflon has eliminated the chainsaw grindy noise but has dampened it. I must now secure 2 new traction wheels and fit these to finish tests. Anyone know much about the maxon motor conversion ?
This page was generated in 0.753 seconds.
