Offline Thewolf
#1 Posted : 11 February 2018 01:18:31(UTC)
Thewolf
Hi everyone Cool
In the continuity of the post'' means of feedback'', it is necessary to check when the rail is'' amputated'' by cutting the bridge of terminal O if there is electrical continuity.
If my memories are good. I may be wrong, if we check with a multimeter to see if the cut-off has been made, there should be no "doorbell".
My multimeter is a MAS830B.
Some multimeters have a bell icon, not mine. Well, I'm looking for it, but I can't see it. I think I need to use the resistance department on the multimeter, the ohms.
Is that correct or not?
Thewolf
Offline French_Fabrice
#2 Posted : 11 February 2018 08:46:33(UTC)
French_Fabrice
Hello Serge,
yes you're right;
see there: http://jbryant.eu/pages/DMM.htm section fuses
fabrice
Offline Thewolf
#3 Posted : 11 February 2018 10:32:55(UTC)
Thewolf
Hello Serge,
yes you're right;
fabrice
Hello FabriceCool
How are you ?
Thank you
Serge
#4 Posted : 13 February 2018 21:14:33(UTC)
Yes, if your multimeter does not have a "continuity" tester with a tone to play back, you can use the multimeter on a resistance setting , and make sure the resistance is maximum (infinite) to show that the continuity is broken or not.
Offline Thewolf
#5 Posted : 13 February 2018 21:17:59(UTC)
Thewolf
Thank you Minok Cool
This page was generated in 0.283 seconds.
