Offline Ove Henning
#1 Posted : 22 January 2018 19:25:34(UTC)
Ove Henning
Hei. Have tried several times, but the only thing that happens is that the switchlamp (74470) blinks a couple of times. The MS does not react when I try to switch. I have tried to set the dipswitch 10 to ON and to "not-ON". All cables are checked. What is wrong?Cursing
#2 Posted : 23 January 2018 02:50:13(UTC)
If the lantern blinks (Dims) at the same time as you are commanding the turnout to switch, it is an indication that power is being drained by the decoder.
My guess is the point motor is either binding , or an end cutoff switch is not working properly (cutting out when it shouldn't)
you could try
- verify that the solenoid motor moves smoothly without binding
- manually position the motor at the other end and retry the command to switch it
It may be that the solenoid will only drive one way.
you should confirm the following in your problem description
- Is this for C-Track or T-Track
- have you soldered the lantern to the decoder
- which solenoid mechanism do you have
- whether the solenoid is tested and known to work nativly (without a decoder)
- If you are using an external power source for the "yellow/white" or tapping of the "Red" for power.
Offline Ove Henning
#3 Posted : 23 January 2018 14:22:46(UTC)
Ove Henning
Thanks for help! I will check all this.
(The switch-motor is driving smoothly, but with the decoder neither to left or to right. C-track, lantern is not solderes to decoder, solenoid-mechanism?, )
This page was generated in 0.227 seconds.
