#1 Posted : 10 January 2018 10:25:18(UTC)
Good morning,can anybody give the numbers of the above similar cars?Thank you very much.
Edited by moderator 11 January 2018 11:18:39(UTC)  | Reason: Not specified
#2 Posted : 10 January 2018 11:26:44(UTC)
Hi Panayotis,
You could start with two fully lit Marklin sets, numbers 42990 and 42991, which were made back in 2002.
#3 Posted : 10 January 2018 11:44:34(UTC)
Thank you very much Kimball.I bought the 26540 Rheinpfeil set and i have to found 43855 and 43865 to make the set better.I have already buy the 43855 and i would like to have and the 43865 too.If the 43865 and 23422 have different numbers i will take both of them.
#4 Posted : 10 January 2018 15:28:36(UTC)
If I remember those items correctly, one of the two separate Maerklin coaches (43855) had red taillights installed at the end of one of the coaches.
As far as the Trix models, the coaches from the set were available individually, including the Avumz, the Apumz, the Dome car and the Wrumh restaurant.
I think that the coach numbers are available at http://mobadaten.de/
The 23422 had the number 61 80 18-80 101-8
There were typically more compartment coaches (Avumh) than open seating coaches (Apumh in any given consist.
The actual consist for the TEE Rheinpfeil can be found here: http://www.heinrich-hank...ildung/e4_rheinpfeil.htm
#5 Posted : 11 January 2018 08:47:58(UTC)
Thank you very much Mike.ThumpUp
This page was generated in 0.264 seconds.
