Offline craigericks
#1 Posted : 03 January 2018 00:31:41(UTC)
craigericks
I have a 60215 CS2 using two boosters. One is a 6017 booster connected to the CS2 using the ribbon cable connection on the bottom of the CS2. The second is a 6014 booster connected to the "6017x" connection on the back of the CS2. I think I need a 60125/60145 terminal box if I get a 60174/60175 booster and a 60065 power pack. If I go with another 6017 and power pack I should be able to "daisy chain" it to the existing 6017. Am I going in the right direction here? And what connection on the CS2 would I use to connect the 60125/60145 terminal?
Craig
P.S. I realize I cannot using the mfx recognition feature on the 6017 powered sections of my layout.
Marklin:CS2 and TrainController Gold v10
#2 Posted : 03 January 2018 01:38:32(UTC)
I would recommend the 60174/5 option over another 6017.
I suggest using your existing 6017 for accessories only, and the CS2 and 60174/5(s) for the layout track work.
The 60145/45 "Terminal" may be connected to the CS2 using the 9-pin "CAN Bus output" socket.
- the terminal comes with a 1.8m cable
- Optionally you may introduce 60126 extension (2m each)
Each Terminal has 4 device outputs that may also be used to help distribute any (future) Boosters (60174/5) , L88 (60883) and MobileStations [requires small 60124 = 7<>10pin adapter cable].
Terminals may be daisy chained , if you need distance/disbursed locations for devices or more device output sockets.
Offline craigericks
#3 Posted : 03 January 2018 02:31:30(UTC)
craigericks
Thank you for the information. My 6017 powers my hidden yard with no problems. I will most likely go the 60174/5 route.
This page was generated in 0.186 seconds.
