Offline JoeB
#1 Posted : 08 October 2017 18:02:20(UTC)
JoeB
The first time I used my CS3 for an extended amount of time the screen started going black every couple minutes. I would hit.the stop button and it would turn back on to the the screen I was on and then turn back off again and would repeat this. Anybody else have this issue. The CS3 seems to have a lot of bugs.
#2 Posted : 08 October 2017 22:45:39(UTC)
Does it have a power saver?
Offline JoeB
#3 Posted : 09 October 2017 02:14:01(UTC)
JoeB
The instructions do not indicate any sort of power saver and have not seen one is any of thd menus
#4 Posted : 09 October 2017 05:35:41(UTC)
Please state the firmware versions of the CS3.
There had been reports of a few funnies after the release before last which seamed to imply a couple of different variants may have made it to the wild.
If you have not done an update , I would suggest you do so.
Offline JoeB
#5 Posted : 09 October 2017 23:13:33(UTC)
JoeB
I have the following
CS3
Hardware version: HW:03.04
Software version: 1.3.1
TFP3
version: 12.28
Offline skukuza
#6 Posted : 17 October 2017 03:13:20(UTC)
skukuza
CS3
TFP3
version: 12.28
Yes.
I have a similar problem in that after about 30 to 40 minutes of operation the power switches off completely on it's own for no reason. I have watched the current draw and it seems to maintain a constant .75 to .8 amps. I also notice that when I put a voltage meter across the track, the voltage seems to pulse and every now and again it drops considerably and sometimes the loco running will give a sudden hesitation.
I've tried changing power packs but still the same. I have upgraded to version 1.3.1 etc. Any ideas anybody?
Kevin
This page was generated in 0.483 seconds.
