Offline chrisisrang
#1 Posted : 04 October 2017 01:51:24(UTC)
chrisisrang
I would like to use Marklin Turntable for my C Track layout. Do I just need to buy Marklin 7287 Extension set for connecting the turntable with my C Track layout or do I need to buy Marklin 7287 as well as C to K Track connectors. Please let me know what are the various parts I need to build the connection with my layout.
Thank you very much for your help in advance.
Chris
Offline applor
#2 Posted : 04 October 2017 02:38:07(UTC)
applor
Hi Chris,
The 7287 set allows you to connect 3x K-tracks to the turntable. You need to purchase a C to K track adaptor in addition to the 7287.
Might be worthwhile building your BW in K track and just use a K to C track adaptor for where it connects to your station area.
It is worth noting that the turntable has recently been discontinued. It may be a sign that Marklin is about to release a C track turntable.
edit: there is also this webpage - https://www.marklin-user...odel/reviews/MR7286.html
You can modify the 7287 connectors for use with C track. It would involve removing the connector tabs on both tracks and just using the rail joiners to connect them together.
You would also need to mount the turntable on an elevated 'frisbee' so it sits at the same height as the C track and extends to the end of the 7287 pieces.
Offline christos563
#3 Posted : 11 June 2018 18:20:39(UTC)
christos563
good evening also from thessaloniki, greece - hellas
you can also use in serie : 7287, 2201, 24922, 24171 etc.
christos
This page was generated in 0.216 seconds.
