Offline LukefromNJ
#1 Posted : 01 October 2017 19:59:07(UTC)
LukefromNJ
I was looking through a PDF copy of the Märklin 0700 track plan book when plan 10 caught my eye:
Although in many ways it's the ideal layout for me, the one problem with the plan is that it's designed for M-track, while I plan on using K-track. There is a K-track version of the plan later in the book, but on the PDF I have it's too small and blurry to read the numbers in the plan. If someone on this forum has a copy of the book, could you upload a higher-resolution scan of the K-Track version of the plan? It's on page 164 (the original plan is on pages 69-72)
Offline mike187
#2 Posted : 01 October 2017 21:36:50(UTC)
mike187
Hello:
Try: www.lctm.info/Secciones/...lioteca/Libros/index.php
They have the track plan book on file.
Regards, Paul
Offline LukefromNJ
#3 Posted : 01 October 2017 22:06:06(UTC)
LukefromNJ
That's actually where I first got the book as a PDF; unfortunately, the scan is too blurry when trying to zoom in to read the track plan for the K track version:
Offline bygger01
#4 Posted : 02 October 2017 12:17:21(UTC)
bygger01
If you are considering using that layout with K rails, then you should take advantage of the flex track to avoid the "boring" S curve in my eyes that is in the lower left corner
And also the far right curv could also be better .....
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
Offline LukefromNJ
#5 Posted : 03 October 2017 00:07:09(UTC)
LukefromNJ
In the original plan, it looks like that S curve on the left was there to make space for the railroad crossing track. If I leave the crossing out, I'll probably make that area one large, gentle curve. I don't plan on following this track plan exactly; at the very least, I'll probably double-track the layout.
Offline applor
#6 Posted : 03 October 2017 10:23:38(UTC)
applor
You have the overall design shape, it would be very easy to design it in K track with layout planning software - and make some design alterations at the same time:)
Offline LukefromNJ
#7 Posted : 05 October 2017 03:00:18(UTC)
LukefromNJ
I'll probably leave the central "core" of the station/crossover/engine depot more-or-less unmodified (although I may shorten the spur above the turntable and change the roundhouse to a 6-stall roundhouse) but change the outer oval quite a bit, depending on how much space I have to work with.
#8 Posted : 05 October 2017 11:00:19(UTC)
..... unfortunately, the scan is too blurry when trying to zoom in to read the track plan for the K track version
Hopefully this is better.
(I re-scanned my own copy of the book some time ago.)
#9 Posted : 05 October 2017 12:30:57(UTC)
Hello David,
Sorry for your trouble, I provided this scanned from my 0700 to Luke by email after PM on 2nd October,
Philip
Offline LukefromNJ
#10 Posted : 06 October 2017 00:02:19(UTC)
LukefromNJ
Yes, Philip PM-ed me a higher-resolution scan the other day. Still, thanks for the scan and track part numbers.
thanks 1 user liked this useful post by LukefromNJ
Offline applor
#11 Posted : 06 October 2017 06:56:01(UTC)
applor
If I were you I'd be re-designing all the points to use wide radius instead. Looks much better and closer to NEM for track parallels.
Offline LukefromNJ
#12 Posted : 10 October 2017 02:59:45(UTC)
LukefromNJ
I might try redesigning some aspects in SCARM; ultimately, it comes down to how much space I'll end up having at my disposal, and how much of that space I'd want to devote exclusively to a permanent model rail layout. What caused me to look to this plan in the first place was that it managed to fit into a relatively small space a passenger & freight terminus station, a locomotive roundhouse and depot, both out-and-back and continuous loop running, potential for a wide variety of passenger and freight operation, and it does it all while avoiding the spaghetti-bowl look a layout with all those features might have.
This page was generated in 0.391 seconds.
