Offline darticus
#1 Posted : 10 September 2017 20:24:52(UTC)
darticus
Marklin insulators only break the connection for a very short distance. If you use insulators, can it be a problem for the loco when the front wheels gets over the insulator and on the second transformer and the back wheels are still before the insulator on the first transformer? Aren't all loco wheels electrically connected to the track? Isn't this two sources of power at one time? Thanks Ron
Edited by moderator 11 September 2017 08:50:57(UTC)  | Reason: Removed capitalisation on topic header - typing in caps is like shouting at everyone! Please don't d
Offline Poor Skeleton
#2 Posted : 12 September 2017 20:40:51(UTC)
Poor Skeleton
Yes, for this short period both power supplies are connected together, however, this isn't a hazard. For modern active controllers (like Marklin's) the higher voltage controller will take over, so you'll be driving with whatever voltage it is set to. For old fashioned rheostat controllers you get a voltage somewhere between the setting of the two controllers. In any case, it will never exceed the higher of the two settings so will be safe for your locomotives.
Chris
Offline JBoldt
#3 Posted : 01 December 2017 12:49:49(UTC)
JBoldt
better to use insulator track to separate two circuits? Not sure, pls advise
#4 Posted : 01 December 2017 17:47:10(UTC)
Poor Skeleton
The insulated joiners are designed to be used as a pair and whilst I haven't tried using them singly, I suspect there would be problems if you did.
Of course, this does mean making an extra power connection for each section of track, but otherwise it's no great hardship.
Be careful when removing the original joiners though, especially from pointwork, as it is easy to rip the rail from the sleepers if you're too rough!
#5 Posted : 02 December 2017 01:05:29(UTC)
Poor Skeleton
Reading back, I think I may have misunderstood the question - apologies for that.
To my mind there is absolutely nothing against using the insulated track joiners other than that you have to remove regular joiners from track sections and have to make your own electrical connections to the new sections.
Admittedly, they do look flimsy, but I've had no problems so far, even when joining to sections of flexible track.
For certain it's a lot less expensive than using ready-made isolating track sections, although the insulating joiners aren't cheap as you have to buy them along with lots of un-needed metal ones. I managed to by a big bag of insulating joiners on ebay for a reasonable price.
Hope that comes closer to answering your question!
All the best
Chris
Offline strummer
#6 Posted : 04 December 2017 02:56:58(UTC)
strummer
This is true: ask me how I know this...Crying
Mark in Oregon
thanks 1 user liked this useful post by strummer
Offline JBoldt
#7 Posted : 07 December 2017 20:00:19(UTC)
JBoldt
Thank you very much...ordered a bag via ebay, will see how it works out
#8 Posted : 07 December 2017 21:47:45(UTC)
Poor Skeleton
It will be fine - I was surprised how well they work, despite their small size.
Guest (5)
This page was generated in 0.246 seconds.
