Offline DB Fan
#1 Posted : 15 August 2017 02:32:11(UTC)
DB Fan
Hello
I purchased on ebay a 3391 that was described as having a binding problem due to incorrect installation. After a while of trying to correct the problem I finally noticed that on the rear drive axle the left wheel is loose. First question: is this normal? If not, is it possible to swap out the complete axle? If that is not possible I guess I have to pull the wheel of and fix it. I know somebody mentioned where to get tools for pulling wheels of the axle but can't find the thread. Can somebody post a link to that website or thread? Any help is appreciated. By the way, I did get a good deal on that engineBigGrin .
Happy Model Railroading
Robert
Offline franciscohg
#2 Posted : 15 August 2017 08:06:03(UTC)
franciscohg
Chile
Hi, this is not normal, the loose wheel leads to a kind of unquartering of the wheels, thus locking the loco to run. You probably must change the wheel to solve the problem, a transitory solution may be to squeeze a little the end of the axle with it in place, then the wheel will be properly secured, at least for a while.
But it will be wiser to order both wheels and axle.
Proper tools can be found here
https://www.fohrmann.com/de/
Offline analogmike
#3 Posted : 15 August 2017 12:36:55(UTC)
analogmike
Also use loctite 648
Offline franciscohg
#4 Posted : 15 August 2017 12:43:48(UTC)
franciscohg
Chile
Yes, it last even less, but can be used anytime....
Offline analogmike
#5 Posted : 15 August 2017 12:59:50(UTC)
analogmike
I don't know the link but it was discussed here.
Offline franciscohg
#6 Posted : 15 August 2017 13:01:00(UTC)
franciscohg
Chile
It did work, i did used, it did not last very long...
Offline DB Fan
#7 Posted : 15 August 2017 17:08:35(UTC)
DB Fan
Hello Mikey
Id that the red permanent or the blue? Thanks.
Robert
Offline DB Fan
#8 Posted : 15 August 2017 17:12:14(UTC)
DB Fan
Hello
After reading my post I wanted to mention that I wanted to ask if the Axle assembly(incl. wheels and gear) could be changed out without removing the wheels. Thank you.
Robert
Offline franciscohg
#9 Posted : 15 August 2017 18:24:35(UTC)
franciscohg
Chile
No, to replace axles and/or wheels you must remove the wheels
Offline DB Fan
#10 Posted : 16 August 2017 03:32:05(UTC)
DB Fan
I was afraid of that. Oh well. just going to order the tools and see what I can do. Thanks for the link.
Robert
Offline Tex
#11 Posted : 20 August 2017 21:58:42(UTC)
Tex
Robert
Robert
Your problem is not that unusual, I have had drive wheels become loose on two older engines, a Marklin Class 44 and a Marklin Class 18.4. Both were repaired by Scot at Helmuts Hobby Specialists. He has stated that it occurs with movement of the softer cast wheels on the hardened steel axle. His repair consists of removing the wheels from the axels, roughening the axel end then pressing the wheels back on using a locking adhesive. Often it is also necessary to straighten the side rods. My engines have operated very well since the repair and Scot has indicated that all the repairs he has made have held up.
Tex
thanks 1 user liked this useful post by Tex
Offline DB Fan
#12 Posted : 20 August 2017 23:36:37(UTC)
DB Fan
Tex
Thanks for the info. I'm going to fix the engine with the method you described. Shouldn't be to difficult to do besides having the wheel in the correct position. Going to make sure it is in the correct position and mark it. Will update on the progress in the fall.
Robert
This page was generated in 0.456 seconds.
