Offline strummer
#1 Posted : 12 August 2017 17:10:45(UTC)
strummer
I just picked up set #8130, with the 8899 4-6-0. I knew in advance that the engine didn't run, but I figured I could get it going, based on all the great info available on this and other sites.
This is my first time dealing with the dreaded "Hardened Oil Syndrome"; boy, you all weren't kidding! After I got all the gears freed up and the motor cleaned, it (the motor) does run, but the wheels don't turn. I figure it's one of two things, and I'm hoping someone here can help.
1. The worm gear is worn, and needs to be replaced. I read a similar thread on this forum about this issue...
2. The gear and shaft of said worm is still frozen. Now, I have not taken the motor off the frame to check this, and so here is my question: do I need to unsolder the motor from the "capacitor" (what is that even for?) and pickup tabs before the motor can be removed?
Any and all suggestions are most welcome! Thanks.
Mark in Oregon
Offline Markus Schild
#2 Posted : 12 August 2017 17:38:37(UTC)
Markus Schild
Hi Mark,
Just remove the one screw which holds the motor. It should go out together with the capacitor. No soldering needed. The capacitor is needed for radio interference suppression. The spare-part sheet helps understanding: https://www.maerklin.de/...r.php?artikelnummer=8899
Markus
Offline Artologic
#3 Posted : 12 August 2017 17:52:06(UTC)
Artologic
Mark,
I have the 8899, it had the same issue, the gear right under the motor was totally stuck on mine, I would start the search there. Also, when you remove the motor, you can check the wormgear while you are at it.
Kristof
Offline strummer
#4 Posted : 12 August 2017 22:21:12(UTC)
strummer
My thanks to you both; I saw some solder at what looks like the connection(s), so I didn't want to force it and risk breaking something.
Will let you know what I find... :)
Mark in Oregon
Offline strummer
#5 Posted : 13 August 2017 00:26:58(UTC)
strummer
Okay gentlemen, this is what I found.
In this case anyway, the contacts were indeed soldered to the motor, so I did have to un-solder before I could remove the motor from the frame.
It was still a very tight fit, and took a good bit of wiggling to finally get it to come loose. I suspect the motor had never been removed, and it had some "gunk" that made removal more difficult. A good cleaning of everything took care of that issue.
The worm looked fine: I think I saw just a bit of wear on the gear that is set well within the frame; once again, a cleaning and careful oiling seemed to free it up nicely.
I re-assembled everything and, with fingers crossed, hooked up the leads from the power pack and it did indeed run. A little rough at first, but I'm hoping with a bit of a break-in it'll be better.
Final thoughts: first off, I appreciate the engineering that went into this design that makes it possible to actually work on something this small. Very cool. Second, it's also nice that Marklin has a support system in place to help with "do-it yourself" repairs, such as that link to the parts diagram. Third, I am once again impressed with how quiet this mechanism is. And lastly, that "Hardened Oil Syndrome" is a real bear...I'm happy I read about it before I began this project! I'm guessing almost any used Marklin loco one purchases will have this condition.
Lots of patience, I think, is the key to working on this small stuff.
FWIW, here's a photo of the lok and its set:
My thanks to all who weighed in... BigGrin
Mark in Oregon
This page was generated in 0.458 seconds.
