#1 Posted : 07 July 2017 12:00:28(UTC)
Just for the record ...
Note:
- code for MS2, Decoder, have been available separately (CS3 or Decodertool)
- mfx+ images reflect those in the CS3.
- The Booster GFP/TFP version (3.68) is higher than that currently available on the CS3
system(v4.2.0) .................. 27-06-2017
WebServer (4) ................... 17.09.2015
cs2-gui (4.2.1(0)) .............. 27.06.2017
Spielewelt Hintergruende(4.2.0) . 01.03.2017
spielewelt dampf(4.2.0) ......... 01.03.2017
spielewelt diesel(4.2.0) ........ 01.03.2017
spielewelt elektro(4.2.0) ....... 01.03.2017
spielewelt(4.2.0) ............... 01.03.2017
gfp(3.68) ....................... 24.05.2017
ms2(2.7) .........................18.02.2017
decoder 3-0-1-8 + 1.032 ......... 25-04-2017
ChangeLog
GUI version 4.2.x (from April 2017)
- New GFP version 3.58 to improve mfx logon problems
- Extension 32 Functions for locomotives (mfx and DCC)
- 32 Read / write functions for locomotive cards
- Mapping and configuration for 32 functions
- Bug Fix: Startup problems fixed with S88
- Bug Fix: Problems with DCC locomotives after multiple stop / go
- Bug Fix: Synchronization of master / slave locomotives
- Bug Fix: Improved graphical user guidance in mapping locomotives
- Bug Fix: Routes are now executed parallel to the GUI
- Readout button at POM disabled
- Bug Fix: Mixing of mfx locomotives with mfx switch decoders fixed (Geisterloks)
- Terms for the world of games between CS2 and CS3
- Deleting locomotives is now immediately visible on the slave
- Bug Fix: DCC address 127 error removed
- Bug Fix: Link88 data is lost during update
- Stop button from the GUI
- Bug Fix: Only one booster could be updated. Then a restart of the CS was required
The following points are still under construction:
- Mouse pointer in GBS changed to crosshair
- Links88 with names and display
- Bug Fix: Loks disappear from "" last used
- Bug Fix: Contact number for pendulum distance was limited to 1024
- Specification of the triggering device in the overload message of the CS
- Bug Fix: Power on booster track after shutdown
- Formatting the CV table for magnetic articles improved
- Symbol alignment improved when inserting in the track image
- Displays the limitation of the locomotive name to 16 bytes
- Bug Fix:
- Bug Fix:
- Bug Fix:
- Bug Fix:
- Bug Fix:
- Bug Fix:
- Bug Fix:
- Bug Fix:
Added more world-wide lobbies
No. loco example wallpaper
4 Goliath crane wagon
10 Traction unit VT 11.5
14 Diesel locomotive F7
18 BR 628
22 Schienenbus
26 Diesel engine V140 / V188
30 Tumrtriebwagen
33 E-Lok Modern gray
41 crocodile
49 Swiss E-Lok AE 8/14
53 BR 103
57 Swiss electric locomotive Re 4 / 4I
Commentary: on Cab ID list
- list is missing reference to IDs 6 (diesel Moderen), 8 (Kran Gelb) which were also part of the download.
- Noting that 33, 41 had been published earlier (may have been just image refresh or bug fix)
- The image file associated with the definition of 18 implies a BR111 rather then a BR628
40system/paket.cs2
.name=system
.descr=Systemdateien in /etc ersetzen, Update erneuern, CS2-Script erneuern, Scripte für Touchscreen angepasst
.vers=4.2.0
.date=27.06.2017
42webserver/paket.cs2
.name=webserver
.descr=Webserver installieren, Verbindung mit Decodertool ermöglicht
.vers=4
.date=17.09.2015
50gui/paket.cs2
.name=cs2-gui
.descr=CS2-Haupt-Programm (GUI) updaten (ohne Spielewelt)
.vers=4.2.1(0)
.date=27.6.2017
56spiel_hintergrund/paket.cs2
.name=Spielewelt Fahrpult Hintergruende
.descr=Bilder der Fahrpult Hintergründe
.vers=4.2.0
.date=1.3.2017
57spiel_dampf/paket.cs2
.name=spielewelt dampf
.descr=Bilder und Filme für Dampf-Loks erweitern
.vers=4.2.0
.date=1.3.2017
58spiel_diesel/paket.cs2
.name=spielewelt diesel
.descr=Bilder und Filme für Diesel-Loks erweitern
.vers=4.2.0
.date=1.3.2017
59spiel_elektro/paket.cs2
.name=spielewelt elektro
.descr=Bilder und Filme für Elektro-Loks erweitern
.vers=4.2.0
.date=1.3.2017
60spielewelt/paket.cs2
.name=spielewelt
.descr=Bilder und Filme für Spielewelt-Führerstände erweitern
.vers=4.2.0
.date=01.3.2017
70gfp/paket.cs2
.name=gfp
.descr=GFP für CS2 und Booster 60174, Boosterbetrieb verbessert, mfx-Magnetartikel finden
.vers=3.68
.date=24.05.2017
71ms2/paket.cs2
.name=ms2
.descr=MS2-Update-Files erneuern
.vers=2.7
.date=18.02.2017
73decoder/paket.cs2
.name=decoder
.descr=Update-Files für Lokdecoder Firmware (mSD und mLD) und Sound-Firmware
.vers=3-0-1-8 + 1.032
.date=25.04.2017
Version: 3.0.1.8 (April 11, 2017)
- Bugfix: Fixed flashing of the outputs when switching on, eg with dimmed or zoomed output
Version: 3.0.1.7 (March 23, 2017)
- Improvement: track H0 decoder for track 1 with more motor current, analogue mode reworked
- Bugfix: Fixed errors in the 2-point controller for automatic sequences (clutch roller)
- Bugfix: Already programmed decoder with other project programming, not all CV ranges were correctly programmed
- Bugfix: Recognition and resolution of a DC brake distance revised
- Bugfix: Load / empty calculation in the sound corrected with extreme ABV
Edited by user 31 August 2017 09:13:53(UTC)  | Reason: Not specified
#2 Posted : 07 July 2017 12:23:25(UTC)
There is no 32 functions with DCC protocol.
Just only 29.
#3 Posted : 07 July 2017 13:07:56(UTC)
Seems there are two different files on the Marklin website for this update.
The Cloud site download has a size of 138,240 KB and a MD5 hash of 0fd74cd869e9fc51790fb3a1a321f7a6.
The Marklin site download has a size of 133,120 KB and a MD5 hash of aee33a784bda0208d3f216ca6abed991.
The MD5 hash file that comes with each of the files says the hash value of both files should be aee33a784bda0208d3f216ca6abed991.
Not sure which file I've used to update my CS2 - it is currently updating. Will check when it is done.
#4 Posted : 07 July 2017 14:56:23(UTC)
I used the cloud version. Not sure if that means that the other file is a down level version, but it does bother me that both are published with the same MD5 hash - quite obviously this is not correct.
#5 Posted : 08 July 2017 02:29:02(UTC)
The observant will have noted that this updates package includes a 42Webserver reverence to v4(no suffix) and date 2015 which is lower/older than the component that shipped with the v4.1.2(3) update a year ago. That packages WebServer component noted v4.1.1 and 24.04.2016.
While not conclusive, the CS2update.log section shows the processing of the 42Webserver with the typical "files to check" but with no apparent update/download of any actual new files. (implies no downgrade either).
As per above comments. Change management has introduced unnecessary confusion and leaves a bit to be desired.
#6 Posted : 08 July 2017 02:37:15(UTC)
NOT cited in the ChangeLog is the presence of an updated mfx definition file - mfxdefs.cs
This now allows the CS2 to better present data for the m83.2 when using the mfx configuration panels.
Note:by "better" it means that numeric codes from the decoder are translated to text - the Text is still in German only
Two other peripherally relevant files that were uploaded are the help files
- hilfe/de/mfx_magcv.html
- hilfe/de/mfx_magnetartikel_einordnen.html
However, don't get your hopes up for some extra help as these are files dated for 2014 and contain nothing more than their own name
#7 Posted : 22 July 2017 08:37:46(UTC)
Cursory update detected for CS2-GUI
Same version - different date.
No file downloads detected.
#8 Posted : 05 September 2017 12:11:24(UTC)
Another cursory (date only) update detected
New icons for
- icons/BR 187 004-7.png (matches 36631)
- icons/BR 187 109-4.png (matches 36630?)
thanks 5 users liked this useful post by clapcott
Offline flying_arch
#9 Posted : 18 October 2017 17:29:59(UTC)
flying_arch
Malaysia
Hi. There is no cs2update.md5 (1 KB) in the website. https://www.maerklin.de/...e/downloads/cs2-updates/
Where I can get it.
Thanks for your help.
This page was generated in 0.474 seconds.
