Offline ktsolias
#1 Posted : 23 May 2017 10:03:11(UTC)
ktsolias
Hi to all
I have a very nice DB BR 85 007 (3309) from 1983.
Is a very nice loco and in excellent condition.
At the moment of production this Loco was at the top of the line.
This 3309 is the version 3309.1 (front staircase open at the bottom).
The Loco has a DCM motor, reversing unit with electronic control, TELEX couplers front and rear, ready for smoke generator 7226 (5mm), 3 lights front and back who change with the direction of travel.
Really a great Loco.
Driving gear and wheels without any wear...
I had converted in the past a 3308 with the 60965 with sound.
For the 3309 the plan is:
1. 60941 HLA motor
2. 60972 mLD3 Decoder (No sound)
3. LED lights (f0)
4. Smoke generator (f1)
5. Cabin LED light (f2)
6. TELEX couplers (f3 front, f4 rear)
The 21pin circuit board gives the possibility to upgrade easily to sound later....
I will publish the conversion process with details for all the members who are interesting in conversions
Costas
thanks 5 users liked this useful post by ktsolias
Offline ktsolias
#2 Posted : 23 May 2017 11:10:47(UTC)
ktsolias
Next step is the dismalding of the Loco.
Unsolder all the wires that keep the old motor, reversing unit etc to the body.
Keep everything that has to gone in a plastic bag (the process can be reversed....).
Not need to take off the running gear(except partially to change traction tires).
The nude frame looks like this:
Careful inspection of the frame and specially the gears, wheels etc. Check that work smooth. (I do some test rounds with the frame towed by another Loco..).
Good cleaning of all the old oil and dirt. (The method depends how much dirty is the Loco. This one was very clean)
Put oil in all the moving parts.
Check again: Everything smooth and quiet.
I decide to use the old reversing unit bracket for the mounting of the decoder.
Screw on the base plate and check that fits the body perfectly!!!
Then the installation of the motor which is straightforward.
Small drop of oil both sides of the rotor axle...
Check the motor with DC 9-16V forward and reverse: OK
Costas
#3 Posted : 23 May 2017 14:31:36(UTC)
great pics and methodical steps.
good decision on no sound. I think they are overrated.
#4 Posted : 23 May 2017 16:23:27(UTC)
one has to experience the sound in the right place, not every train room is suited for a sound decoder, it depends on the size, size does matter.
Offline petestra
#5 Posted : 23 May 2017 16:27:26(UTC)
I love my 3309 BR85 with sounds too. One of my best conversions! BigGrin ThumpUp ThumpUp ThumpUp Peter.
Offline ktsolias
#6 Posted : 24 May 2017 11:13:06(UTC)
ktsolias
Next step is the installation of the electronic circuits.
According to the targets of the project, the theoretical plan is the follow:
And the table with the part list needed:
First I did the preparation of the ΤELEX couplers.
Soldering new very thin 36 AWG wires. (Black and Orange)
I did one more mass connection in the front coupler, as the articulated frame of this Loco plus the way the body is connected to the frame does a lot of problems with the ground contact (Brown wire).
As you can see I have put protecting diodes on both TELEX couplers. Is not necessary actually and I have done conversions (BR 86) without diodes with the same decoder without problems. The Power consumption of each TELEX coupler is less than the 250mW of the AUX of the decoder. Plus I don't use the TELEX in Continuous mode. But any way I put them.
I decided to solder the SMD components (resistors and diodes) on the 21 pin circuit board after preparation.
First I intefify the lines to the funtion cables on both sides of the board. Then find a suitable area to remove the vernish and expose the cooper line.
Front side: f0 (front) grey wire
Rear side: f2 (cabin light) Br/Gr, f3 (front TELEX) Br/Ye, f4 (rear TELEX) Br/Wh
For f0(rear) it was not possible because the space is very limited. So I will do a small PCB in the rear to solder the resistor there.
Then remove of the cooper with a 1.5mm drill carefully
Then solder the SMD components according to the plan
The whole procedure is very demanding and needs precision and patience, but is worthy to do. If you do any mistake you just change the holder not the decoder.
But this does wiring so much easier and specially in Locos with limited space!!! (Märklin do that with special holders in the whole line)
That's for today.
I had enough fun!!!
Thanks for your nice commends.
The sound or not sound in conversions is something that we have discuss a lot. I think that first is a matter of money (3x the decoder) for something that I am not convinced that is necessary-especially for electric Locos.
In this type of conversions -with 21 pin holder- to and sound is just 5 minutes. Find space for the speaker (or the right speaker, there are speakers for every space) plug the new decoder and speaker!!! That's all.
Costas
Offline Crazy Harry
#7 Posted : 24 May 2017 15:09:00(UTC)
Crazy Harry
Costas,
Great work and excellent step-by-step presentation! I like the idea of soldering the resistors and diodes directly to the 21 pin holder where possible, very clean. Nice work with the fine wires for the Telex. What gauge is the rest of the wiring (the ones that come with the 21 pin holder and your function wires (brown with stripes))? Do you use nickel-silver or copper wiring?
The Marklin site doesn't state the dimensional information for the decoder and its associated components, could you post them here? Length and width of the 21 pin holder and the thickness of the bracket + holder + decoder chip assembly. Do the typically fit in the space previously occupied by the anolog reverser?
Sorry for all the questions, hope you have time to answer
Harold
Edited by user 24 May 2017 20:50:02(UTC)  | Reason: more questions
Offline ktsolias
#8 Posted : 24 May 2017 23:24:02(UTC)
ktsolias
Costas,
Harold
Thank you Harold for your nice comments
Usually I am using the wires that are come with the decoder. In special occasions (TELEX, Loco-Tender) I use ESU 36 AWG. They are available in ten different NEM colors no Märklin color code.
All are copper.
The dimensions of the complex bracket + holder + decoder are: W=35mm H=21mm to 18mm D=9mm. You must add 1-2mm for the wires.
Usually the space of the old reversing unit is enough. In the case of electronic reversing units you can use the old bracket.
Of course there are some locos with very limited space. In these rare cases you have to use a decoder in plastic wrap like 60982 60985 etc or to create the space (not recommended except you are very experienced and have the right tools).
The problem is the speaker. But in the market there are many. You must be very careful with the resistance of the speaker. Must be the right for the decoder. Most modern decoders working with 8 or 4 Ω speakers.
You can feel free to do questions. In this forum there are many people who like to answer questions...
Costas
Edited by user 30 May 2017 10:06:11(UTC)  | Reason: Not specified
Offline franciscohg
#9 Posted : 24 May 2017 23:39:00(UTC)
franciscohg
Chile
Great work Costas!!!! and greater documentation of it!!!!! Congrats!!!!!
In older locos with telex i have used relays to feed them, even if the comsuption is not that high....just scary.
Other interesting point is the smd components, i must add that 21 mtc ESU platines comes ready to install them, just need to solder.
Francisco
#10 Posted : 25 May 2017 02:03:18(UTC)
I'll soon show my BR 85 conversion, my own had at least 4 different upgrade versions. this time it will have lots of accessories.
Offline ktsolias
#11 Posted : 30 May 2017 09:57:33(UTC)
ktsolias
Hi to all
Time for the final step of the conversion, the wiring, the lights, the installation of the decoder.
The wiring was done according to the plan.
The 21 pin holder
The motor
For the ground (brown wire) I did a connection to the front coupler. So I have 4 connections: Rear coupler, Front coupler, Motor screw, and soldering point in the middle of the frame from where the ground goes to the 21 pin holder.
In the rear of the loco I did a small contact PCB. On this I solder the SMD resistor for the rear LED light (680Ω), and I used it as a distribution PCB for the +18 (Orange wire) and the cabin LED.
The rear LED and the Cabin LED (WW SMD)
For the front LED I used a WW SMD LED in the original position.
And the final look of the Loco after all the wiring done with a 60972 decoder in place
A check of all the connections was done before the installation of the decoder.
Everything OK. Test run: Beutifull
The Loco is going so beutifull that I decide to and SOUND!!!
I plug a 60945 decoder, that I had in stock, plus the speaker in the space in front of the 21 pin holder.
This is the great advantage of the 21 pin holder: 5 minutes no soldering at all!!!!
Check with the body on: OK no problem so there was no need to use a smaller speaker.
The final photo of the Loco
Runs excellent, very smooth the motor is very Quiet.
Here is a video
Märklin 3309 Digital
Thank you for your patience and your nice commends.
I hope that some members may be inspired for this to do their own conversions.
Costas
Edited by user 08 June 2017 22:06:54(UTC)  | Reason: Not specified
thanks 4 users liked this useful post by ktsolias
Offline ac jacko
#12 Posted : 31 May 2017 13:21:18(UTC)
ac jacko
Loved the process in pictures Cool
Guest (14)
This page was generated in 0.572 seconds.
