Offline Johnvr
#1 Posted : 17 May 2017 19:20:41(UTC)
Johnvr
Yesterday I fried a 60945 Marklin Sound Decoder for Steam Locomotives Angry Angry Angry
My friend Joe had come over and we were installing a 60945 MSD in his Steam Loco.
The loco was running up and down the track, and we tested all the lights on the decoder. Everything was working.
We then put some smoke fluid into the smoke stack and turned the smoke unit on.
Suddenly the CS2 went on the blink, the decoder started burning and smelling, and it was all over in a second.
The decoder was well and truly fried, and the decoder now only burns and lets off smoke if we connect it again.
I suspect that the smoke auxiliary function touched a ground somewhere on the chassis, and short-circuited the decoder.
Which has got me thinking about installing a fuse.
I am thinking about installing a fuse between the CS2 and the Track.
After all, blowing a fuse is much less expensive than blowing a 60945 or a CS2 even.
Do you think that blowing a fuse would have prevented the decoder from burning out ?
Why didn't the CS2 detect the excessive amperage and shut down before the decoder burned out ?
If you think it is a good idea to install a fuse, what rating should the fuse have ?
I'd like to get your thoughts please.
Regards,BigGrin
#2 Posted : 17 May 2017 19:44:31(UTC)
Views messages in topic : 11,161
How about the decoder controlling a relay that connects the smoke unit to track power & chassis ground instead?
Since you don't give any info on the loco model or motor setup, it's hard to know why it happened.
Normally there are protective diodes to prevent decoder burnout, and I thought mSD would have that just like ESU...
#3 Posted : 17 May 2017 20:01:00(UTC)
Decoders are sensitive pieces of electronic equipment. I've blown several over the years whenever I've failed to take proper care with my wiring and connections. This is usually caused by me being in a hurry to finish the conversion and not checking everything properly.
It doesn't take long for a decoder to fry if voltage or ground is applied to the wrong part of the circuit. The damage is usually done in milliseconds and in my opinion a fuse would not have even started getting warm in this time.
Apart from the motor the biggest consumer of current in a loco is a smoke generator. For this reason they are often connected through a relay as Juhan has suggested above. In John's case either the decoder output was insufficient to handle the current draw of the smoke unit or the function wire to the smoke unit was shorted somehow. The relay would have helped here.
I don't think a fuse between the CS2 and the track would protect the decoder, though it could well add a level of protection to the CS2. You state that the CS2 started "going on the blink". This would be the over-current protection kicking in, so that at least did work well.
Offline Johnvr
#4 Posted : 17 May 2017 20:24:16(UTC)
Johnvr
Juhan,
It was Joe's Marklin 37015 , the K. Bay.Sts.B , green loco with two large drive wheels.
It comes fitted with a 21-pin plate in the Tender, with the decoder on the plate.
The Smoke Unit came separately and one needs to remove the body to install the smoke unit manually.
There is no possibility of a relay in this case.
Regards,BigGrin
#5 Posted : 18 May 2017 16:18:34(UTC)
Hi John and friends
I had in the past a short between one output and the ground and the decoder 60645 I think swichted itself off and restarted. On another one it fried after many hours of operation. So there is a protection but it is far from being 100% effective😳
Now i have to buy more at 73 euros (60945) and it does not look the price will go down soon.
#6 Posted : 18 May 2017 19:02:47(UTC)
Juhan,
Regards,BigGrin
Check if copper plate contact for the smoke generator did not touch the body of smoke generator.
Maybe you did install smoke generator wrong?
#7 Posted : 18 May 2017 22:29:10(UTC)
The controllers already have short circuit protection in case the track power is grounded short, but that likely would not have helped in your case. Adding a fuse to the to-track power feed isn't usefull as the MS/CS/etc already have circuits to provide that protection as they monitor the current.
In your case, the output or power stages of the decoder board likely cooked off. It may well be a short from the smoke function output line to the body. You would have needed a fuse between that output and the smoke generator, and even then you would have to take care that you install the fuse correctly without a short before the fuse.. so there's still an opportunity to mess the fuse install up.
The power stages of the decoders can only handle a limited current and would fry long before the MS/CS likely could ever detect a short.
And then it could have been a board level failure to the smoke generator output lead (f1?).. a defect in the board. Of the contact was some how grounded via a screw, etc.
The best solution is just handle the decoders wisely (ground yourself first to dissipate static), be deliberate and slow in the work you do (don't rush or skip visual checks), and you can use a multimeter/tester to check outputs are not grounded before applying power if your paranoid.
But fuses, I don't think would have helped in this case unless it was a precisely specified fuse installed just on the smoke generator output and installed correctly and there wasn't an issue ON the decoder board or how it was contacting the body of the loco. The fuse only protects against things that are bad AFTER the current gets through the fuse.
Offline rugauger
#8 Posted : 19 May 2017 16:14:05(UTC)
rugauger
+1 for the multimeter! And use of it is mandatory, not paranoid Wink My boss always says: "check, check and check again"...
I agree that a fuse would not have helped since its "reaction time" would have been too long in any case.
Perhaps next time install the smoke generator and then before you wire it up to the decoder, test its function with an analog transformer first by simply holding a wire to the connector. Then, once you're happy there is no short, connect to the decoder and check everything with a multimeter.
Finally, are you sure there is no place in the tender for a relay? You can get miniature relays with a very small footprint these days.
Richard
#9 Posted : 20 May 2017 00:06:14(UTC)
bummer of an experience for sure.
Have installed relays for smoke units, for example in my 3048
http://cabin-layout.blogspot.com/2004/02/installingdigitaldecoder.html
But the relays I obtained are really designed for 12 Volts, and I think the decoders put out more than 12V.
What relays have others used?
Edited by user 20 May 2017 03:44:59(UTC)  | Reason: typo
Offline mario54i
#10 Posted : 20 May 2017 18:19:36(UTC)
mario54i
Miniature solid state relays are quite effective for moderate currents, say to 1 A.
This is an example
http://www.mouser.it/Pro...JKYUEHNj3mgE1OnoxQ%3d%3d
Besides being much smaller than conventional relays, even miniature ones, the input drive is an LED, it works at 5 - 10 mA max. It could in principle be driven even by logic level decoder outputs.
Just be aware that output is not a mechanical contact, it's a transistor, it can't bear high overload even for short time.
#11 Posted : 20 May 2017 19:05:42(UTC)
According to NEM 660 the permitted load on logic level outputs is 0.5 mA.
Unless your decoder permits a higher load, you still have to add a transistor to drive that "solid state relay".
#12 Posted : 20 May 2017 20:45:11(UTC)
This is an example
Thanks, that looks very interesting. I assume that one would then include a resistor on the function output of the decoder to ensure that the current is limited to 10mA. I think the load should stay well below 1A for a single smoke unit. I guess one could put a diode in the load side so that it chops half the digital current if there is a chance a smoke unit will exceed 1A.
I wonder how hot the relay gets?
This page was generated in 0.598 seconds.
