Offline southernkiwi
#1 Posted : 09 May 2017 22:35:00(UTC)
southernkiwi
I have a DCC Minitrix setup using two MS2 controllers. After much perseverance, I now have both MS2 units happily controlling my various different locos. I recently decided to add a DCC points controller (LDT S-Dec-4-DC) to my layout but this is where I am having problems.
I can get the master unit to control the points but not the slave unit. The slave unit shows the points change on the display when the master unit changes the points, however the slave unit itself won't change the points.
Does anyone know how I can make the slave unit work? The MS2 manual isn't the most informative piece of literature.
Thanks for your help.
Z-Gauge: Engines - 5 steam, 7 Diesel, 9 Electric.
#2 Posted : 10 May 2017 01:41:13(UTC)
The MS2s have a setting for protocol that is to be used for All accessories (you cannot mix DCC and MM in the same MS2 only environment)
I presume you have set your Master MS2 for Accessory control using DCC.
However, is the protocol setting on your slave MS2 also set the same ?
#3 Posted : 10 May 2017 09:03:30(UTC)
southernkiwi
Thank you, that was exactly the problem. Thanks for your help.
This page was generated in 0.192 seconds.
