Joined: 20/07/2007(UTC) Posts: 809 Location: Leopold, Victoria
 An easy way to keep your wiring loom tidy. |
Legless Era's 1 to 111,C track,k track |
 14 users liked this useful post by Legless
analogmike, rbw993, Danlake, Roland, PJMärklin, kimballthurlow, Carim, Johnvr, Br502362, ixldoc, Minok, seatrains, French_Fabrice, Jabez
Joined: 18/03/2007(UTC) Posts: 6,765 Location: Brisbane, Australia
Originally Posted by: Legless   An easy way to keep your wiring loom tidy. And bonus........ use a small screw-in hook under the baseboard to hook up a tie at each application. Kimball |
HO Scale - Märklin (ep II-III and VI, C Track, digital) - 2 rail HO (Queensland Australia, UK, USA) - 3 rail OO (English Hornby Dublo) - old clockwork O gauge - Live Steam 90mm (3.1/2 inch) gauge. |
 2 users liked this useful post by kimballthurlow
Joined: 20/01/2015(UTC) Posts: 1,204 Location: Kerikeri
legless, you might have done the same thing by interweaving the black cable tie. Nice idea, Those things can be expensive in NZ.
Dereck. |
Northland. NZ REMEMBER 0228 for ä |
 1 user liked this useful post by dominator
Joined: 23/07/2014(UTC) Posts: 8,509 Location: ENGLAND, Didcot
Originally Posted by: Legless  ....
An easy way to keep your wiring loom tidy. Good grief, that is getting a bit fancy I'll have to remember that one.
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
Looks very neat, but I don't have any wires that thick on my layout!  |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
Joined: 15/10/2006(UTC) Posts: 2,319 Location: Washington, Pacific Northwest
Excellent idea, as it is much cheaper than purchasing actual cable routing raceway (Slotted Wall Wiring Duct for example, like this: https://www.digikey.com/...0189/277-5412-ND/2525017 ).  What some do is rather than raceway is they use the flexible binding combs as slotted ducts/raceway.  But then the wires are all inside the one comb and hard to clearly see. Your approach makes following a wire much easier. I wonder if there was an "ugliest train table underside" contest how bad it would be. :) |
Originally Posted by: dominator  legless, you might have done the same thing by interweaving the black cable tie. Nice idea, Those things can be expensive in NZ.
Dereck. Just go to Bunnings |
Originally Posted by: Minok  Excellent idea, as it is much cheaper than purchasing actual cable routing raceway (Slotted Wall Wiring Duct for example, like this: https://www.digikey.com/...0189/277-5412-ND/2525017 ).  What some do is rather than raceway is they use the flexible binding combs as slotted ducts/raceway.  But then the wires are all inside the one comb and hard to clearly see. Your approach makes following a wire much easier. I wonder if there was an "ugliest train table underside" contest how bad it would be. :) I think that's a great idea, but boy that would be a hard one to judge since I've seen some very bad ones |
Joined: 17/09/2006(UTC) Posts: 18,778 Location: New Zealand
Originally Posted by: Legless  Originally Posted by: dominator  legless, you might have done the same thing by interweaving the black cable tie. Nice idea, Those things can be expensive in NZ.
Dereck. Just go to Bunnings Or The Warehouse.
