Offline avi57
#1 Posted : 25 March 2017 17:22:55(UTC)
avi57
Israel
I replaced the traction tires on GG-1 with the original tires #7153.
The problem is that now all 4 traction wheels don't have contact with the tracks.
What is wrong and how should I fix that
#2 Posted : 26 March 2017 05:31:40(UTC)
Probably you do not put them with the right way.Or you put the tyres on wrong wheels.The wheels we can put the tyres have a slot.In this slot you have to fit carefully the tyres.
#3 Posted : 26 March 2017 14:27:59(UTC)
I am guessing that while you were replacing the traction tires, you somehow dislocated the mechanism that allows the bogie to pivot, causing it to not sit properly on the rails.
Offline avi57
#4 Posted : 26 March 2017 21:41:06(UTC)
avi57
Israel
Thanks, I checked both suggestions. These were not the problems. Any more ideas?
#5 Posted : 26 March 2017 23:09:23(UTC)
Shalom Avi
My strong suspicion is that the power bogies were not re-assembled properly and/or the powered bogies are not seated properly in the chassis
Could also be that the pony wheels and their chassis are not mounted in the proper sequence.
Just in case, here's the exploded view
https://medienpdb.maerkl...es/1/pdf/37490_explo.pdf
Besseder?
Good luck
Edited by user 27 March 2017 11:09:37(UTC)  | Reason: Not specified
Offline ktsolias
#6 Posted : 27 March 2017 20:09:27(UTC)
ktsolias
Hi Avi
Have you put the small springs (one each track) again in their Place
The springs are no 40 in the plan
Costas
Offline avi57
#7 Posted : 27 March 2017 22:25:28(UTC)
avi57
Israel
Many thanks for the good advises.I examined again the diagrams and found the problem.Avi
This page was generated in 0.422 seconds.
