3 Pages<123
Offline Armando
#101 Posted : 05 March 2017 01:33:00(UTC)
Armando
Challenger.MOV (1,805kb) downloaded 137 time(s).
Hello all,
I've finally received my 39911 - Challenger.
I installed the two 7226 smoke generators in it, according to the scant instructions included. They do operate, and give off a lot of smoke!
However, one thing that I'm noticing, which worries me, is that when I turn the smoke function on, the headlight (both front and rear) flickers for a few seconds and then everything seems to operate normally again: headlights on and smoke generation.
Has anyone experienced the same situation with his Challenger?
The video that I have attached shows the instant when I turn on the smoke function on my CS2 and when the smoke generators start operating, after the lights stop flickering. BTW, this has never ever happened with any of my Big Boys which also take 2 smoke generators!
Another issue that I found, right at the beginning, was that one of the 4 screws that hold the locomotive onto its protective base was stripped and it gave me some trouble to finally be able to remove. BTW, the screws are not the same alloy as the ones on the Big Boy.
Edited by user 05 March 2017 06:15:24(UTC)  | Reason: Added a video attachment, added more text.
Armando García
thanks 1 user liked this useful post by Armando
Offline baggio
#102 Posted : 05 March 2017 03:02:53(UTC)
baggio
It seems that your power consumption approaches the limit that the layout can stand when you turn on the smoke function.
I am no electrician, but when you first turn the light on at home is when power is absorbed the most. That is why in the homes there are lights that take their time in coming on fully. My kitchen has this type of light. That is why you have the flicker when you turn on one more device that needs plenty of power.
Have you ever noticed anything like this in the past when you actually ran out of power on the CS?
You may want to ask the seller what he thinks of this and whether it's a known problem or to be expected.
If it does not create problems, it may not be such a big deal since you said afterward everything is all right and the video shows it.
Just my 2 cents' worth. BigGrin
(Nice loco, by the way. ThumpUp )
#103 Posted : 11 March 2017 04:40:02(UTC)
I got mine too.Simply amazing.Drool LOL Love BigGrin Wub ThumpUp
Offline Armando
#104 Posted : 12 March 2017 02:41:04(UTC)
Armando
Tikanis!
Indeed the locomotive has impressive sounds and overall performance.
Are you going to install the smoke units in it? I've been looking at some videos on youtube, and the model seems to experiment the same issue with the headlights when the smoke function is engaged. They flicker, until the smoke begins to flow. A friend has recommended using Seuthe 11 instead of the 7226, as per the Märklin operating instructions.
I've written to the Märklin customer service to inquire about this issue. However, no reply as yet.
Enjoy your fine locomotive!
Armando García
#105 Posted : 12 March 2017 04:42:20(UTC)
Tikanis!
Only when i am sure about the result.The only that i have to do is to set the sounds a little lower,i think they are very loud.I have to wait to run the locomotive in another layout to enjoy her,mine have catenary system and in some positions is impossible to run.Thank you Armando,regards,Panayotis.ThumpUp
#106 Posted : 12 March 2017 09:22:09(UTC)
Maybe I will buy one if cheaper.
Offline Marius in Africa
#107 Posted : 15 March 2017 02:21:39(UTC)
Marius in Africa
Received my copy as well. What is Marklin trying to prove by setting the sound levels so unrealistically high?
Marius in Africa
thanks 1 user liked this useful post by Marius in Africa
#108 Posted : 15 March 2017 08:47:31(UTC)
Who knows,who cares?You can reduce the sounds easily with your controller.I noticed that too,the sound level is very high.LOL
#109 Posted : 15 March 2017 15:19:02(UTC)
Speaking of which...I have tried every single possibility available on my ECOS, there seems to be noway to accomplish any re-programming of any CV from this 39911 decoder.
Is this the one that will baffle me?
Don't tell me I have to buy an MS or CS, because I won't!
Opinion/advice anyone?
#110 Posted : 15 March 2017 16:09:34(UTC)
You have been a member since:: 16/02/2004(UTC)
Hi, Jacques,
According to the product database the 39911 support mfx and DCC.
One approach: (temporarily) disable M4 in the ECoS and set the volume using DCC programming. (*)
Standard approach: with M4 enabled change the volume the "normal" way (I presume you tried that already without success).
(*) If CVs are not documented in the loco manual, try the settings from the MSD/3 documentation.
#111 Posted : 15 March 2017 16:48:24(UTC)
Hi, Jacques,
Hi Tom
I have tried changing CV's using DCC programming, MM and also temporarily disabling M4 as you said.
Nothing works!
It looks like the Ecos cannot modify the CVs (but it reads them) , starting with CV50 which contains the bits to set up priorities on the various modes (analog, MM, DCC, M4 etc)
I'm dumdfoundedCursing
#112 Posted : 15 March 2017 23:06:18(UTC)
Hi, Jacques,
Hi Tom
Nothing works!
Do you have a Lokprogrammer? I managed to change some Cvs in my new ET194 with a Lokprogrammer (because that was the only programmer available to me at the time). The ET194 I believe has an msd/3.
#113 Posted : 16 March 2017 04:30:22(UTC)
I do not know the way to change locomotive's parameters with my CS2.If it is necessary i am using my old trusty 6021.Maybe i will leave the sounds of the challenger the way they are.
#114 Posted : 16 March 2017 07:58:05(UTC)
Hi, Jacques,
Hi Tom
Nothing works!
That's one I did not try! Thanks for the idea Alan!
I am going to unearth that tool ...and give it a try!
Will keep you posted.
#115 Posted : 16 March 2017 15:23:22(UTC)
I figured you of all people would have one ... BigGrin BigGrin BigGrin
#116 Posted : 21 March 2017 16:21:04(UTC)
Well, guess what...
It worked!
The lokprogrammer did its job.
Another trick for the tool kit!
Alan, I owe you a **big** Challenging BigGrin one. ThumpUp
This coming September probably in Goeppingen? Wink Smile
#117 Posted : 21 March 2017 16:53:49(UTC)
Well, guess what...
It worked!
I hope to be in Goeppingen. probably will not be there until the Friday evening. Wife wants to have a couple of days in St marie au Mines first to visit the quilt show that is there every year, and every year it is on the same weekend as the Marklin do! Cursing
Offline abisel
#118 Posted : 14 May 2017 15:06:09(UTC)
abisel
Originally Posted by: grnwtrs Go to Quoted Post
Originally Posted by: Tower Go to Quoted Post
I received my 39911 on Saturday, unfortunately when I opened it I noticed that the coupler between the Locomotive and Tender was broken. Fro replies to my facebook post on marklinusers.com's facebook page I am not the only one with this problem it seems.Cursing Cursing Cursing
So very,very sorry for you, and your model. The model looks excellent, but "failed drawbar' is no excuse, for shame on MarklinCursing
Hope Marklin fixes soon, very soon.
regards,gene
I too received my 39911 with a broken drawbar. It broke right where the rear pin slides in the slot of the tender. A plastic drawbar is not appropriate, it should be metal. And the angle between the loco and the tender put a bind of sorts on the drawbar which may have contributed to the failure.
I ordered two drawbars for replacements.
Can anyone get with Marklin and advise them to upgrade the drawbars to metal for both the Challenger and BigBoy? Maybe a hinged drawbar to allow up/down movement to help eliminate the binding?
1
Offline jerdenberg
#119 Posted : 04 April 2019 19:05:23(UTC)
jerdenberg
Sorry for resurrecting an old topic. I just received my 39911 back from Märklin where it had spent about two months in repair. When I had purchased it new at my local dealer in February, the same problem as Tower's became apparent upon opening the box – broken coupler.
Today, the coupler is OK, but now that I can actually run the loc there is a new problem: it's quite prone to derailments on tracks that have not caused any derailments of the two Big Boys presently active. The tender derailed easily in an R2 curve, while the front wheels did so at a slight bump in the tracks.
In view of the very positive remarks in preceding posts, I wonder if I have overlooked something in preparing it to run, or there is something wrong with the loc?
Jeroen
Offline dickinsonj
#120 Posted : 06 April 2019 22:04:21(UTC)
Originally Posted by: jerdenberg Go to Quoted Post
S
Jeroen
My #39911 tracks perfectly on my layout. I can't really think of anything that you could have not done in preparing it to run, so I am guessing that the problem is with your Challenger. If the areas on your track which cause problems for the Challenger don't bother your Big Boys then I am guessing that there is something else wrong with it and it might need to go back to Märklin.
Have you checked with your dealer to see what they suggest?
Offline jerdenberg
#121 Posted : 08 April 2019 13:29:30(UTC)
jerdenberg
Thanks Jim, for strenghtening my suspicion that my Challenger is a problem child.
In the weekend I ran it again to see if I could diagnose the problem, and one glaring symptom that something is wrong is shown in the following picture (on R3 track no less):
39911 wheel lift
The entire loc body tilts a little into the curve, but that happens with the Big Boys too and all their wheels remain in contact with the track, so the picture hints at a problem with the connection of the second set of drive wheels to the loc body. Indeed, when I laid a Big Boy and the Challenger on their sides, the second set of drivers of the Big Boy could be tilted both lenghtwise and sideways relative to the loc body, while that of the Challenger could only be tilted lengthwise.
Another difference, probably caused by the (deplorable) move of the Challenger slider to the tender, is that the third and sixth axles of the tender, which for a Big Boy do have less lateral flexibility than the other tender axles, have almost no lateral flexibility. Whether this by itself caused the derailment of the tender I experienced, or it was related to the problem with the second set of drive wheels, I do not know.
So, back to the dealer again …
Jeroen
thanks 1 user liked this useful post by jerdenberg
Offline dickinsonj
#122 Posted : 08 April 2019 14:34:32(UTC)
Jeroen
Jeroen,
It is always good when you can find a symptom that clearly shows what the actual problem with a loco is. There is no way that your Challenger can track properly when something like that happens, especially on a fairly large radius curve like R3.
My Challenger is not currently on my track but I may have the time in the next few days to see how it behaves in a curve, and I doubt that it does what yours is doing. By comparing a model which works properly with one that does not you can often get to the source of a problem and I think that you have made a good start.
If I do test mine in the next few days I will post what I discover.
Offline jerdenberg
#123 Posted : 09 April 2019 15:45:57(UTC)
jerdenberg
Today I took my Challenger to my dealer, and as expected, it derailed immediately on entering the first curve. The dealer then undertook a diagnose-and-repair session on the spot, which after removal of the loc shell showed that the loc end of the loc–tender coupler could not move freely in its guiding slot. After some manipulation, freedom of movement was restored, but it was not clear whether this was the result of smoothing the guide or the chance removal of some object that had impaired movement. Upon reassembly, the Challenger then happily ran around R2, into R1 along narrow curved turnout, and back again. It is now running on my layout as it should. Kudos to the dealer!
Jeroen
thanks 3 users liked this useful post by jerdenberg
Offline dickinsonj
#124 Posted : 09 April 2019 16:26:26(UTC)
Jeroen
Yes - good job by the dealer but not such good work by Märklin who obviously did not install the replacement coupler correctly when they had it for service.
It is a beautiful loco however and I'm sure that you will have a lot of fun seeing it run now that it is working properly. ThumpUp
Offline jerdenberg
#125 Posted : 09 April 2019 17:38:38(UTC)
jerdenberg
Indeed, I was lucky to have the dealer make the repair instead of sending it off to Märklin again for two months or so. As the dealer said, "the person who repaired the coupler must have been sleepwalking or half asleep". A simple test run at Märklin should have exposed the failed repair immediately. The note on the repair form from Märklin was ominous in hindsight: "coupler repaired, and functions [not "function", JS] tested" …
Jeroen
Offline klarinettmeister
#126 Posted : 10 April 2019 15:57:21(UTC)
klarinettmeister
Nice to hear the problem was resolved easy. I recently had a problem also with a TEE unit where one of the couplers didn't move at all on one car thus the coupler propably would break in a curve. I realized that Märklin had installed one boogie incorrectly. That was an easy fix.
thanks 2 users liked this useful post by klarinettmeister
3 Pages<123
This page was generated in 0.860 seconds.
