Offline baggio
#1 Posted : 05 March 2017 02:50:52(UTC)
baggio
Hello, Everyone:
Does anyone know if older decoders, like Delta or C80, consume substantially more power than the modern ones, especially MFX decoders?
I ask this question because I am finding that my Delta/C80 decoder loco that now runs just fine, seems to require substantially more power than more recent locos.
However, at the same time I had the Delta loco fixed, I doubled the space of my layout (not a big one to begin with anyway). I connected the inside loop that I was planning to use either in DCC/AC or simply DC (with a separate power supply) and turned it into one oval with inside another oval and powered by one MS2.
The power shuts out when I use the older loco with another loco and the entertainment car playing music.
Two modern locos and the entertainment car do not have this effect. At least this is my preliminary observation.
The Delta loco by itself and the entertainment car together are fine.
Any thoughts?
Thanks.
BigGrin
#2 Posted : 05 March 2017 08:49:57(UTC)
Hi, Silvano,
Wrong question I would say.
These old AC/DC motors draw more current than later DC motors (so-called "high efficiency motors").
Those old decoders (C80, Delta) also have a low PWM frequency. This could make a difference for the overload detection of the MS2.
The MS2 is good for 1 through 7 running trains. When AC/DC motors are involved, you may find that three are one too many.
#3 Posted : 05 March 2017 10:12:25(UTC)
Hello, Everyone:
Any thoughts?
Thanks.
BigGrin
Tom is correct in saying that it is the motors and not the decoders that make these older locos draw more power.
Actually they are in most cases linked because the older decoders did not require a DC conversion of the motor so tended to keep the original, less efficient, AC motor.
Offline baggio
#4 Posted : 06 March 2017 00:42:36(UTC)
baggio
Ray: "Actually they are in most cases linked because the older decoders did not require a DC conversion of the motor so tended to keep the original, less efficient, AC motor."
So, then, if I buy a nice vintage loco of the 60's and have it digitized WITHOUT changing the motor, do I run the risk of having the same problem I do with the T80 decoder on the 3000 (that I can ONLY run that loco and no others at the same time)?
(Mike changed the motor on my FS 424 and I do not have this problem. ThumpUp)
Offline Tex
#5 Posted : 06 March 2017 03:00:11(UTC)
Tex
Baggio
I still have an old 3000 class 89 loco from my original digital starter set purchased 28 years ago. It is crude looking compared with my other eight steam locos and i have never thought that it was worth upgrading so it has the original old style motor and c80 Marklin decoder. It still runs well at normal settings of my 6021 control unit but it is just used to test track and it is not assigned to regular service, I listed it on e bay for $ 30 and got no interest so I plan to keep it for another 28 years!
Tex
thanks 1 user liked this useful post by Tex
Offline baggio
#6 Posted : 06 March 2017 03:46:36(UTC)
baggio
Hi, Tex:
Thank you for your feedback. I was not thinking of getting rid of it, but I am disappointed that it takes over the layout.
Do you have the same problem?
Regards.
Silvano (my real name).
#7 Posted : 06 March 2017 09:16:06(UTC)
Hi, Tex:
Regards.
Hi Silvano,
I don't have any problem running two Delta or 6080 locos at the same time on my MS2. Maybe it's the entertainment car which draws more power?
Do you have anything else powered from the track, like lights or accessories? If you do you should change the way they are wired to draw their power from a separate power supply if possible.
Offline baggio
#8 Posted : 06 March 2017 12:27:31(UTC)
baggio
Hi, Ray:
The station platform has the lights on all the time.
The entertainment car is on most of the time on a siding, but it seems to create no problems with the C80 loco. I can have it playing music and it does not affect anything. It's when I start moving another loco that the MS2 shuts off.
Regards.
Silvano
P.S. In some of your posts you seem to use the term "6080" and "C80" interchangeably. Do the two mean the same thing? Thanks.
#9 Posted : 06 March 2017 13:46:48(UTC)
Hi, Ray:
Regards.
Silvano
Yes they mean the same thing. 6080 is the part number and C80 is the name of the decoder.
How do you power your station lights? Are they powered from the track feed? If so they may be taking up some of the power available for the trains. If they are powered from a separate supply then they will have no effect.
Offline eroncelli
#10 Posted : 06 March 2017 16:48:05(UTC)
eroncelli
The best solution in this case is to upgrade the motor (not changing it but simply switching the "wound" stator to a "magnet") with a 4th generation decoder.
Actually, there is only a "modern" (dated anyway more than 10 years) decoder that uses the old ac Marklin motor (by Uhlenbrock) as it is, but it's a very cheap solutions (deprecated in my personal idea).
thanks 2 users liked this useful post by eroncelli
#11 Posted : 06 March 2017 21:53:44(UTC)
The power consumption of the locos grows with the speed. I can imagine that Ray's locos only draw half the current of Silvano's locos.
The Uhlenbrock decoder 76200 requires a modification of the motor - just a re-wiring, but you end up with four motor connections instead of three.
The current drawn with this decoder could be a bit higher than other decoders, but you get load regulation. And you can keep the decoder if you convert the motor later on with a permanent magnet.
The TAMS LD-W series can be used without motor modification (except for the LD-W-2 that also has four motor connections).
You can use almost any decoder with those AC/DC motors. Märklin do that with the mfx versions of the old 3015 crocodile in various colours.
No load regulation, but can be done.
Offline baggio
#12 Posted : 07 March 2017 01:47:52(UTC)
baggio
Thanks again for the feedback, guys. BigGrin
I am unclear as to one point here: Do ALL locos built in the 60's have a power hog motor?
(If so, then it becomes imperative to change the motor when one converts the loco to digital. This is what Mike did with my FS 424 and I have no such problems.) ThumpUp
My plan for this loco is for now to leave it as it is. I will use it if and when I want to and then I just run this loco on the layout.
I will check to see what happens if I remove the lights from the station platform and if this solves the problem, I will then use my Marklin AC transformer of yesteryear.
#13 Posted : 07 March 2017 08:26:01(UTC)
How do you define power hog motor?
The old 3015 crocodiles have the standard motor of 1 gauge locos.
I think DCMs run better than SFCMs and LFCMs. With a field coil they will draw more current than modern DC motors with permanent magnets.
Some locos from the ’60s have very large flanges that will rattle on C track. It cannot harm to focus locos from the ’70s and later with DCM for use on C track.
Offline baggio
#14 Posted : 07 March 2017 12:46:34(UTC)
baggio
A loco that prevents you from using another loco at the same time because the power will shut off. This is the problem with the Delta/C80 loco.
Offline baggio
#15 Posted : 08 March 2017 05:46:20(UTC)
baggio
I just did it: Without the lights in the station platform, I can run the Delta loco, the FS424 and have the entertainment car with the lights on and the music playing. BigGrin
BUT, if I add the lights from the platform, kaput. The power goes off. Sad
I am thinking of using my analogue Marklin transformer to power the station platform. I think this is what Eroncelli suggested.
Good night from Toronto. Over.
#16 Posted : 08 March 2017 08:38:19(UTC)
I thought as much (I did mention it in my post above...)
Everything you connect to the power from the tracks takes some of the current available, leaving less for the trains. I have all my lights and solenoid accessories powered from my old 6001 transformer leaving the maximum amount of power available for the trains.
For my coaches with lights I am slowly adding battery powered LED strips. These are not cheap but you save on the cost of pickups and current conducting couplers. They come on when the train starts to move and go off again a couple of minutes after it has stopped. They draw no power at all off the track and are a moment's work to add in most coaches. They are made by a company called Train Tech and I heartily recommend them!
This page was generated in 0.569 seconds.
