Offline Hhjg2y
#1 Posted : 13 December 2016 17:03:26(UTC)
Hhjg2y
I have a 60215 and for the first time ran the sound update. After the lengthy download, how can I access and how do I make use of the new updates?
Thank you!
#2 Posted : 13 December 2016 17:13:59(UTC)
The sound files should be on the USB stick.
Plug the USB stick into your PC and you can copy the sound files to your hard disk.
Use the Märklin decoder tool (MDT) to create own sound projects from the library.
Most locos are locked against sound updates, so you most likely need an MSD bought separately to try the sound projects you created with the MDT.
Offline abisel
#3 Posted : 13 December 2016 17:17:35(UTC)
abisel
I tried to download the sound files from Marklin but keep getting the Page Not Found error 404. In fact, I get this error in several different places.
Does anybody else get this error? What is the fix?
I get the errors if I use IE or Firefox
#4 Posted : 13 December 2016 17:57:39(UTC)
Originally Posted by: abisel Go to Quoted Post
What is the fix?
Use the CS2 to download the sound library like the thread starter did - at least I assume that is what he did.
Off topic: have you tried the link on the German Märklin site? They will fix broken links on the German site quickly.
Offline abisel
#5 Posted : 13 December 2016 18:15:14(UTC)
abisel
I tried the German language on the Marklin web site and the links work. so... I think the conversion to English is not yet completed and that is why I get the 404 error messages.
I sent Marklin an email explaining that the web site with the German language selected has more links that all work than if the English language is selected. The few links on the English language version are broken and give the Page Not Found error 404. Who knows when they will fix this.
Edited by user 14 December 2016 00:25:07(UTC)  | Reason: Not specified
Offline Hhjg2y
#6 Posted : 13 December 2016 22:26:16(UTC)
Hhjg2y
What is the fix?
I used the CS2 to download the files.
This page was generated in 0.505 seconds.
