Offline dewalds
#1 Posted : 07 December 2016 07:28:28(UTC)
dewalds
Hi All
Hopefully someone has had this same experience,
Updated the my CS2 over the weekend and I now have a strange intermittent Flicker on my Signals and on one of my Railbus interior lights every 10-15 seconds or so for about a second, this cycle is then repeated non stop.
Signals are connected to Home Made modules, was working fine before the update, even disconnecting all signal module, the railbus the shows the same Flicker.
All running is as was, Loco lights do not do this and also all other interior lights are fine. (The railbus is connected to the running unit via current conducting couplers).
I have CS2 connected to a transformer and feeder wires every 2 meters,
Running 4 S88 modules, all connected away from the power wires to ensure no interference, all S88 track connections run in a seperate sleave away from any power wires, all S88 feedbacks work perfectly.
I have disconnected about every decoder module, unplugged all DC transformers powering accessories and still cannot get rid of this.
Any ideas would be highly appreciated.
Kind Regards
This page was generated in 0.287 seconds.
