Offline MaerklinLife
#1 Posted : 30 November 2016 17:32:40(UTC)
MaerklinLife
Hi all
A friend of mine has a Märklin BR 152 of the new kind with center motor and all four axles powered, blah, blah and so on.
Now in the instructions it says that the bearings need oil every 40 running hours or so. Now, to my knowledge the locomotive uses these bearings as the common ground. Won't oiling them - even slightly - disrupt the power flow? I mean, if oil gets into the bearings - even if I use the recommended Märklin "Special" Oil (7149) it cannot be good for conductivity?
Does anyone have any experience?
At least the class 218 is constructed in the same way, so the question is valid for that loco as well...
#2 Posted : 30 November 2016 19:55:19(UTC)
I guess if you follow the manufacturers instructions you can't be held at fault if it breaks.
#3 Posted : 30 November 2016 20:11:23(UTC)
I nowadays only use one lubricant for mechanical stuff... Even on squeaky door hinges at home... BigGrin
Faller Teflon lubricant , since it's safe also for plastic gears in locos and I think it's the perfect one-oil-for-all purposes. Works very well for me.
#4 Posted : 01 December 2016 07:00:31(UTC)
MaerklinLife
True, but it is still insanely annoying to clean a locomotive from oil. I was just wondering what other people do. I am pretty sure that oil in those places would prevent a good power pick up.
Offline dickinsonj
#5 Posted : 02 December 2016 01:42:30(UTC)
I oil mine on the schedule that Märklin recommends and I have had no issues of any type. I always clean my locos thoroughly before oiling though, so they are kept very clean. That kind of maintenance is part of the fun of model railroading for me and gives me a chance to really get to know my locos. BigGrin
My cardan shaft drive locos all run perfectly and I have never had a problem with either power conductivity or performance. IMO it was about time for Märklin to move past the DCM motors and drivetrains. They were fine in their day and I bought a beautiful VT 11.5 set with that motor just last year. But I really like the new drivetrains, and they seem to be a nice step into the future for Märklin.
#6 Posted : 02 December 2016 08:39:43(UTC)
Most of us have been guilty of over-oiling our locos at some point. It's the combination of oil and carbon dust from the brushes that forms that awful goo which gets everywhere.
Jim has the right idea; keep the locos as clean as possible inside and oil the bearings very lightly according to Marklin's instructions.
Offline dickinsonj
#7 Posted : 02 December 2016 13:40:56(UTC)
Ray has the right advice about the other main lubrication issue with locos - they need to be oiled very lightly. I have a clock oiling kit that has an extremely fine oil application tool and that is what I use to oil my locos. Our locos are much like mechanical clocks in that over oiling them is a much bigger problem than under oiling in most cases.
Offline nitramretep
#8 Posted : 02 December 2016 18:21:09(UTC)
nitramretep
That Faller Teflon Oil is great, I have used it for the last few months and found it helps to reduce the gunk build-up. I think it helps in keeping the track free of the black streak stuff...my constant enemy!
Offline sgtb
#9 Posted : 02 December 2016 19:02:27(UTC)
sgtb
I use synthetic oil myself and think its great.
On the original question oil does conduct but has a resistance on flow. but what were using it for does affect anything.
BobBigGrin
thanks 1 user liked this useful post by sgtb
This page was generated in 0.520 seconds.
