Offline petestra
#1 Posted : 29 November 2016 12:43:29(UTC)
Hi Friends. The Märklin Digital Facebook page has been quite helpful to me lately. I told them how I operate my mid-sized layout
with 2x MS2s and that signals/switches are controlled to a separate analog transformer. Yesterday they advised me to separate the
brown wires that control train track from the accessories grounds. I wanted to hear your thoughts on this too?
Peter Cool
Edited by user 29 November 2016 16:38:44(UTC)  | Reason: Not specified
#2 Posted : 29 November 2016 13:06:41(UTC)
Hi, Peter!
Can be separated for turnouts and signals, but for (some) level crossings you need a common ground.
Such a separation is simple for C track (even when using circuit tracks), but complicated for M track.
Theoretically that separation is not needed. Practically it may have some advantages. At least until you install a level crossing.
What was the question? What was the answer?
Do you have any problems?
Offline petestra
#3 Posted : 29 November 2016 13:22:00(UTC)
Hi Tom. Thanks for your informative reply as usual. I had asked them that if I wanted to get the new CS3 would I have to convert
my Märklin wires 7101 etc to the thicker gauge wires for train running? They had told me that I could still use M wires and there was no need
for the thicker gauge ones. That's when they told me about the brown ground separation. I am still "on the fence" about getting the CS3. I may
just keep using the 2x MS2s. Cheers,Peter Cool
PS - I don't have a level crossing.
#4 Posted : 29 November 2016 13:54:39(UTC)
But you could.
:o)
Offline Torstein
#5 Posted : 29 November 2016 14:01:33(UTC)
Torstein
Hi Peter.
Strange ?? Central station 3 must be connected to DC current, is this the reason for separate ground?
My CS2 get DC but I have no problems with 6 AC trafo and common ground with track.
Or is this answer only for prevent something? (Marklin plug and play)
Torstein RollEyes
thanks 1 user liked this useful post by Torstein
#6 Posted : 29 November 2016 14:22:34(UTC)
I'm afraid I can't see why "they" would recommend separating the ground wires. I can't think of a technical reason for it.
Offline petestra
#7 Posted : 29 November 2016 14:51:35(UTC)
That's what I thought, Ray. If you are on Facebook you may wish to follow the conversation On those Marklin Digital pages. I don't think I will bother
since I've been digital 3 years now and there have been no problems. Cheers, Peter Cool
Offline petestra
#8 Posted : 29 November 2016 14:53:32(UTC)
Originally Posted by: Torstein Go to Quoted Post
Hi Peter.
Torstein RollEyes
Thanks, Torstein. They didn't give a reason. Peter Cool
Offline petestra
#9 Posted : 29 November 2016 14:57:15(UTC)
Here is the conversation on Marklin Digital Facebook pages. Peter
more comment
Marklin Digital Hello Peter! Happy Thanksgiving to you too!
The voltage output from the MS2 power supply is essentially the same output requirement from the CS3. Therefore, it is not necessary to change out your track wires to an thicket gauge.
The question of booster needs is dependent upon load of the system. How may trains are running concurrently? How many lights are using track power? How many feed wires are wired to layout? All of these questions can sway the answer.
The size of your layout can certainly be operated without a booster no problem. If you start to detect digital control errors, then you can try another track feed first. If the error is consistent around track, then you may consider a booster.
If you need any further explanation, please let us know.
Unlike · Reply · 2 · November 23 at 5:15pm · Edited
Peter Nicholas Fragasso Thanks. All accessories are wired to separate transformers so a CS3 to run 8 trains should be ok. I don't always run 8 at once, that's just the max.
Like · Reply · November 23 at 6:23pm
Marklin Digital Yes, your setup should be ok. I would recommend if you are using a common ground for accessories, you should separate the grounds, if possible.
Unlike · Reply · 1 · 18 hrs
Peter Nicholas Fragasso Marklin Digital OK, good to know but why is that? So you mean to separate the ground for trains from the grounds for accessories?
Like · Reply · 17 hrs · Edited
Edited by user 29 November 2016 21:43:53(UTC)  | Reason: Not specified
Offline Torstein
#10 Posted : 29 November 2016 15:24:38(UTC)
Torstein
Peter, keep us update if you get any answer.
thanks 2 users liked this useful post by Torstein
This page was generated in 0.453 seconds.
