Offline nygma
#1 Posted : 14 November 2016 12:52:09(UTC)
nygma
Hungary
Hi Guys,
I am not sure which is the best section to post this in, but here is goes:
I have an Era II tank car in Gauge 1, like this.
But I am missing entire platform with the railings and the cabin next to the tank. I tried searching for it on the Marklin site hoping that it is available as spare, but no luck.
Any ideas where can I get one? Or if by any chance somebody has a broken wagon with this detail?
Thanks a lot,
Csongor
Offline Markus Schild
#2 Posted : 14 November 2016 22:01:32(UTC)
Markus Schild
Hi Csongor,
This seller has the parts you are looking for on Ebay:
http://www.ebay.de/itm/h...sid=p2141725.m3641.l6368
Markus
Offline nygma
#3 Posted : 15 November 2016 08:43:12(UTC)
nygma
Hungary
Thanks Markus, the breakman house and the ladder+railings will cost me as much as the wagon cost me second hand BigGrin
Hi Csongor,
Markus
#4 Posted : 15 November 2016 08:57:16(UTC)
Markus Schild
now I also found back a page with some important part numbers for 1-gauge cars.
http://nymphensittiche.n...tzteile/ersatzteile1.htm
You are looking for 533250 and 596640 . Good luck.
Markus
Offline nygma
#5 Posted : 15 November 2016 09:35:01(UTC)
nygma
Hungary
Hi Markus,
This is useful information as well, though some of these part numbers are either not found or not available on Marklin site. I think I will be better off using eBay.
By not speaking German I can't really leverage Google as English search results usually don't yield any useful results.
Markus
#6 Posted : 15 November 2016 10:18:22(UTC)
Markus Schild
I tried a translation of the list:
________________________________________
Märklin 1- gauge spare-parts
For passenger-cars(5808, 5809, 5810, 5811, 55031, 55033, 58092, 58093, 58111, 58101)
482960 Trittstufe rechts step tread right
482970 Trittstufe links setp tread left
Historic refrigerator car
583080 Klauen-Kupplung (Befestigungsschraube dafür: 583110) Coupling, screw for coupling
588330 Doppelspeichen- Radsatz twin-spoke wheel-set
592090 Kupplergriffe (4 Stück) handle-grips for coupler
581080 flacher Stangenpuffer flat buffer
581790 gewölbter Stangenpuffer round buffer
765830 Feder für die Puffer spring for buffer
581080 Pufferkörper body for buffer
358030 Schlussscheibenhalter (4 Stück) holder for signs for the last car (4 ea)
481680 Rangierertritt tread for shunter
582900 rechtes Hängeisen right stirrup (suspension of the wheelset)
582910 linkes Hängeeisen left stirrup
358260 Trittstufe (Laderaum) tread (loading -door)
G10
700440 Scheibenradsatz wheel-set, solid wheels
761730 flacher Hülsen- Puffer flat buffer
761740 gewölbter Hülsen- Puffer round buffer
765660 Feder für die Puffer spring for buffer
358190 Spritzteil Bremsanlage plastic-part breaking system
358240 Spritzteil Luftleitung plastic-part air-system
358260 Trittbrett zum Laderaum tread (loading -door)
481680 Ramgierertritt tread for shunter
X-car
599370 Griff handle grip
583280 Schlussscheibenhalter (2 Stück) holder for signs for the last car (2ea)
596310 Spritzteil Bremsumlenkung plastic-part breaking system
596290 Luftleitung lang air-tube, long
596300 Luftleitung kurz air-tube, short
593790 Bremserbühne brakeman’s platform
596380 Bremskurbel brakeman’s crank
Brakeman’s cab on platform
Bremserhaus 533250 (58063) Brakeman’s cab
Fenster Bremserhaus 599620 window for Brakeman’s cab
Dach Bremserhaus 599550 roof for Brakeman’s cab
Bremserbühne 596640 brakeman’s platform
Bremsspindel 599560 spindle for brake
Brakeman’s cab for G 10 and similar cars
Dach Bremserhaus 534010 (5830), 534060 (5831). 358740 (5837) roof for brakeman‘s cab
Bremserhaus 534020 (5830) 534070 (5831), 532340 (G 10 aus 5501), 532400 (5837), 547590 (5427) Brakeman’s cab
Fenster Bremserhaus 530530 window for Brakeman’s cab
Treppe Bremserhaus rechts 358770 stairs for Brakeman’s cab, right
Treppe Bremserhaus links 530470 stairs for Brakeman’s cab, left
Passenger-car 58021
210297 Puffer rechts buffer, right
210298 Puffer links buffer, left
765660 Druckfeder für Puffer spring for buffer
210299 Trittstufe rechts tread, right
210301 Trittstufe links tread left
210328 Tritt (überhalb der Trittstufe) tread (upper one)
210326 Faltenbalg rubber-roll
210356 Bremsschlauch rechts brake-hose, right
210358 Bremsschlauch links barke-hose left
210354 Drehgestell 1 truck 1
210355 Drehgestell 2 truck 2
#7 Posted : 15 November 2016 10:38:19(UTC)
Moved topic to the 'Big scale' forum.
I have a Marklin 58663 set of 3 Shell G1 tank wagons. Two of the wagons are missing the footplate, handrail, steps and the ladder going to the top of the wagon.
I was going to ask if anyone knew where to source them from (and part numbers), but I think I've found the answer!
http://www.ebay.de/itm/H...3Ag%3AOl4AAOSwNsdXSe%7Ek
Edit: It isn't an exact match for the ones on the wagons, but better than nothing.
#8 Posted : 15 November 2016 15:01:02(UTC)
This is awesome information. Thanks guys.
Is it worth making a Sticky topic in the Big Scale section?
This page was generated in 0.746 seconds.
