Joined: 11/11/2016(UTC) Posts: 8 Location: England, South Croydon
I have a Marklin HO digital train set bought in 1987/8, so is a generation 1 digital type. I have 7 locomotives of various types including the ICE version 1 digital. I do have one non-digital steam loco which I do not want to upgrade. I have original Marklin track with remote switched manual points/turnouts. I have no signalling. I would like to upgrade my set to modern DCC so I can add DCC with sound trains to the layout. I am thinking of using a Pico smartcontrol system with two wireless cabs. My question relates to the locos. Can my generation one digital sets be upgraded to DCC? If so, which decoders would you recommend? I assume I can just unplug the old digital decoders in the locos and replace them with the new DCC decoders, assuming the same pin layout and space. Modern DCC decoders look very compact so I would doubt any issues with space. Finally, assuming I would like to get someone else to do the work, do you know anyone who could do this upgrade on my Marklin locos? Many thanks for your help, Jim. South Croydon, Surrey
Joined: 14/03/2005(UTC) Posts: 15,870 Location: Gibraltar, Europe
Hi Jim,
I see a couple of issues with what you intend.
First of all Marklin digital systems have their own protocol which is not directly compatible with what you call "DCC". This is not a problem if you don't intend to use any Marklin decoders and just convert all your locos to DCC using other manufacturers decoders. If that is so then you can use the Piko system you are referring to.
The other issue is with your assumption that the Marklin locos have plug-in decoders. I'm afraid that is not the case, except for very recent locos. The decoders are all hard-wired in, so they need to be upgraded by someone who is handy with a soldering iron.
In both cases above there are exceptions in very recent locomotives and decoders from Marklin.
I would encourage you to go digital, and if you fancy the Piko system then "DCC" is the way to go for you, but read up on the current Marklin systems too, which use a protocol called MFX. Many find MFX to be more attractive to them, and all MFX controllers are also capable of handling original Marklin digital too, so you would be able to convert your locos one by one and still run the older ones.
Good luck! |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
You are most helpful, thank you Ray.
I did realise Marklins new digital format is MFX and I noticed some new decoders do MFX and DCC although they seem to be expensive. I chose DCC because of the huge choice of trains available. I can do soldering but would probably pay for an expert to do the job.
However, I didn't realise the newest Marklin controllers would also work on version 1 Marklin digital. Maybe I should just update to the new Marklin system and leave the trains alone. Is there any way I can buy new DCC/Sound locos and have them work on this system without changing the decoders in the new trains to MFX or MFX+?
What do you think of Marklins new wireless cabs?
I must say, Ray, your way seems a lot easier if I can buy and run any DCC/sound trains as well as my old ones.
I would value your opinion. Jim.
Joined: 04/04/2013(UTC) Posts: 1,291 Location: Port Moody, BC
I use a CS2 to run my layout and my Marklin locomotives run on MFX or MFX+ protocol. My non Marklin 3 rail locomotives run on DCC with full sound.
I would value your opinion. Jim. Hi Jim, You can buy a new Mobile Station (MS2) which will run all your old Marklin digital trains as they are and also be able to handle DCC equipped locos as well as new MFX locos if you so wish. You can typically get a complete MS2 system for less than £100 if you go to a dealer who is willing to split a starter set. Here's an example: http://www.ebay.co.uk/it...3540?hash=item3f643549c4 |
Joined: 04/05/2015(UTC) Posts: 777 Location: England, London
Hi Jim
I have a layout which is not going to win any prizes for scenic artistry or sophistication - however it encompasses Marklin digital from 1985 to the present day in 10 loks and a few turnouts and uncouplers. We have a variety of digital control systems from the original 6021 through to a new MS2 with the loks going from "coffee grinder" sound and flickering lights to the full bells and whistles.
And significantly I live in Purley which is probably less than two miles from you!!!!!
You may like to contact me and you can pop round and have a look - but my soldering skill are limited so I will not be a help in the upgrading stakes!
Roger Williams
By the way, I saw the news about the tram accident near Sandilands. I've been many times on that tram heading to my Sister-in-law's in Beckenham. Sad to hear about the deaths. Hope no-one you know was involved. |
Joined: 05/12/2008(UTC) Posts: 1,806 Location: Crozet, Virginia
Originally Posted by: PMPeter  I use a CS2 to run my layout and my Marklin locomotives run on MFX or MFX+ protocol. My non Marklin 3 rail locomotives run on DCC with full sound. Pretty much the same for me too. I run MM, mfx, mfx+ and DCC all from my CS2, and all of my locos work really well together. I have a 60215 running the latest software and it handles all of the protocols simultaneously and seamlessly. As a software developer I have been quite impressed with the multi-protocol performance and ease of use of the Märklin digital control systems. |
So many trains and so little time. |
 1 user liked this useful post by dickinsonj
Joined: 16/02/2004(UTC) Posts: 15,450 Location: DE-NW
Hi, Jim! Originally Posted by: jimfew  What do you think of Marklins new wireless cabs? Which ones? The MS2 has a cable - but they manage to make it look like an antenna on catalogue pictures. The wireless controllers are for starter sets. There are apps for some smartphones. |
Originally Posted by: dickinsonj  Originally Posted by: PMPeter  I use a CS2 to run my layout and my Marklin locomotives run on MFX or MFX+ protocol. My non Marklin 3 rail locomotives run on DCC with full sound. Pretty much the same for me too. I run MM, mfx, mfx+ and DCC all from my CS2, and all of my locos work really well together. I have a 60215 running the latest software and it handles all of the protocols simultaneously and seamlessly. As a software developer I have been quite impressed with the multi-protocol performance and ease of use of the Märklin digital control systems. Hi Jim\ many thanks for your help. Have you ever run older version 1 Marklin digital as well as all your other digital trains (at the same time on the same track)? Jim.
Originally Posted by: H0  Hi, Jim! Originally Posted by: jimfew  What do you think of Marklins new wireless cabs? Which ones? The MS2 has a cable - but they manage to make it look like an antenna on catalogue pictures. The wireless controllers are for starter sets. There are apps for some smartphones. Hi Tom, you raise an interesting point. I was interested in the 60657 (MS2) which I can use two together on my track BUT it does still come with a connecting wire and whilst it is mobile it is not wireless. This seems no better than two CS3+ which whilst not mobile as such, has everything except wireless. Oh dear I seem to be drawn back to the wireless Piko Smartcontrol and upgrading the decoders in my locos. Has anyone added new DCC decoders to old Marklin digital trains? People seem to like the Gold decoders or ones from Bachmann. Jim.
Originally Posted by: RayF  By the way, I saw the news about the tram accident near Sandilands. I've been many times on that tram heading to my Sister-in-law's in Beckenham. Sad to hear about the deaths. Hope no-one you know was involved. Hi Ray, nasty accident. My family and I sometimes use the tram, They do go far too fast on this section and an accident was inevitable sooner or later. I did not know any of the dead or injured people. Jim.
 1 user liked this useful post by jimfew
Originally Posted by: jimfew  Originally Posted by: H0  Hi, Jim! Originally Posted by: jimfew  What do you think of Marklins new wireless cabs? Which ones? The MS2 has a cable - but they manage to make it look like an antenna on catalogue pictures. The wireless controllers are for starter sets. There are apps for some smartphones. Hi Tom, you raise an interesting point. I was interested in the 60657 (MS2) which I can use two together on my track BUT it does still come with a connecting wire and whilst it is mobile it is not wireless. This seems no better than two CS3+ which whilst not mobile as such, has everything except wireless. Oh dear I seem to be drawn back to the wireless Piko Smartcontrol and upgrading the decoders in my locos. Has anyone added new DCC decoders to old Marklin digital trains? People seem to like the Gold decoders or ones from Bachmann. Jim. OK, I think I need to install decoders and have chosen the Lenz Gold 10410-01, a neat small decoder without a plug (I am told the old digital Marklin loco decoders are directly wired and don't have plugs). A little more e3xpensive at £35 each (I need seven). I might have a go myself but does anyone know someone who could do the installation? Anyone used the Lenz decoders before? Jim.
Joined: 28/02/2011(UTC) Posts: 82 Location: Lithgow NSW Australia
Hi Jim
You asked,"Anyone used the Lenz decoders before?"
Yes, I have, and they work well.
I have converted all my old Marklin locos to run on DCC. I have used a range of decoders from manufacturers such as TCS and Lenz but have now largely standardized on ESU decoders. Most of my conversions were done without an upgrade to 5 pole motors. I simply replaced all the wound field coils with Hamo or ESU permanent magnets. All locos run well, particularly those locos that have the LFCMs.
I just checked up on the specifications of the Lenz Gold 10410-01 as I had a concern because you descibed it as a "neat small decoder". It is neat and small because it is designed for N gauge locos. i would advise against using it in your Marklin locos as it is designed for the lower electrica lcurrents in N gauge locos. Instead, if you have your mind set on a Lenz product, I would recommend a larger Lenz decoder intended for HO locos, or an ESU LokPilot V4.0 DCC 54611 decoder. Most decoders come with an 8 pin plug which can simply be cut off before doing a direct soldered installation
One thing that has not been specifically mentioned is that if you intend to use a DCC decoder, you MUST replace the wound field coil in any of your locos with a permanent magnet. These can be obtained from most ESU dealers. You must specify the type of motor for which you require the magnet: i.e. LFCM, SFCM or DCM.
Might I also encourage you to have a go at instaling the decoder yourself. It is not too difficult, and you will find that, like most things, it becomes easier the more you do it.
I hope this may assist you
Regards Geoff
Regards Geoff Many thanks Geoff, most helpful. I agree about the Lenz decoder and have no problem using the ESU decoder you mention. Can I ask why I need to replace the wound coils for magnets? I assume this is only necessary on AC motors but all mine are first generation digital DC motors (as far as I can tell) so I think do not need this mod. Can you comment? I have seen a video of this mod being done and it is too much for me, I would need to pay someone else to go it. Jim
Regards Geoff Many thanks Geoff, most helpful. I agree about the Lenz decoder and have no problem using the ESU decoder you mention. Can I ask why I need to replace the wound coils for magnets? I assume this is only necessary on AC motors but all mine are first generation digital DC motors (as far as I can tell) so I think do not need this mod. Can you comment? I have seen a video of this mod being done and it is too much for me, I would need to pay someone else to go it. Jim Hi Jim The reason for replacing the field coils in Marklin AC motors with permanent magnets is that DCC decoders are designed for use with DC motors. Marklin AC motors can be modified to run on DC current without replacing the field coil by using 4 diodes or a rectifier bridge around the field coil, and I suppose would then run using a DCC decoder, but it would not be advisable in my opinion because it would not overcome the inherent problem of poor speed control present in AC motors. Many years ago (back in the early 1980's as I recall) I fitted rectifier bridges around the field coils of all my Marklin locos to run them on DC and avoid the flashing lights and jumping loco whenever you reversed them. When I became aware of the existence of Hamo permanent magnets, I converted all my locos because of the improved speed control that this modification offered. Later, when digital operation of model trains became a reality, I chose to use DCC, instead of the Marklin system, as it was designed for DC motors and was cheaper. If your locos are already fitted with permanent magnets, then no changes are necessary and it just a matter of removing all existing wiring and installing the new decoder. One further thing: be aware that the colour coding of DCC decoder wires is different to Marklin decoders. Geoff
Hi Geoff, Many thanks for this, most enlightening.
However, I think I have failed. My Marklin digital set has a third rail and centre pickups on my locos. I am advised that upgrading this is impossible, In addition I cannot expand my network with two rail DCC and new DCC trains won't run.
I have decided to scrap my old set and start afresh. I am going or an ECoS controller with two wireless controllers and a large Atlas HO grade 83 track layout. I have bought two DCC trains with sound.
Thanks to everyone who helped me.
I am looking for good quality signalling. What do people recommend. I understand the Atlas signal system is good.
Also, to show off DCC and sound at its best, what train (loco and carriages) would people recommend with most functions and sounds.I did see an O grade set where the doors opened at a station on all carriages. Can you get this feature on HO?
Jim.
Hi! Originally Posted by: GLI  Marklin AC motors can be modified to run on DC current without replacing the field coil by using 4 diodes or a rectifier bridge around the field coil, and I suppose would then run using a DCC decoder, but it would not be advisable in my opinion because it would not overcome the inherent problem of poor speed control present in AC motors. The standard Märklin motor is an AC/DC motor and runs on DC without any modification. Some folks use two diodes to bypass the mechanical reverse unit in order to control direction of travel with reversing polarity. Märklin decoders operate those motors with DC. You need special decoders and further motor modification to get Back EMF and load regulation with that motor. IMHO this is not worth the effort. Originally Posted by: jimfew  I did see an O grade set where the doors opened at a station on all carriages. Can you get this feature on HO? Roco did that for H0 coaches, at least for one type of coaches. Each coach has a decoder and a random generator is used so that doors do not open and close at the same time. I think they made a few one-time series a few years ago and do not have them in stock. |
Joined: 23/07/2014(UTC) Posts: 8,491 Location: ENGLAND, Didcot
Jim. Marklin have simulated this on a modern DMU by having each door as an LCD that displays the doors sliding and video of people exiting and entering the coach. There is also a Trix version available.
