Offline marklin-ho
#1 Posted : 02 November 2016 01:19:49(UTC)
marklin-ho
I don't know if this topic came up already once,
I try to build the Polar Express HO for my Marklin lay out. Right now there are producer LIONEL and BACHMANN
- Which of this 2 brand work the best on Marklin.
- Is it even worse the Time and Money to try to alternate them for Marklin?
There is always the question does the model hold on the Marklin track due to the Wheels, Able to Pass over Marklin Switches and Curbs.
Bachmann has the better model Pere Marquette #1225 (HO 2-8-4 Berkshire)
Any help and suggestion are welcome.
Offline dominator
#2 Posted : 02 November 2016 21:20:19(UTC)
dominator
Looks like 2 rail to me. Will that be a problem. They say C track will allow 2 rail operation but will it allow operation through switches etc.
I am a 3 rail purist so would not contemplate using a 2 rail loco.
Dereck
Offline marklin-ho
#3 Posted : 04 November 2016 14:24:08(UTC)
marklin-ho
Yes Bachmann is a 2 rail System, I will have to install the shoe for the 3 rail Marklin system.
I'm more worried about the wheel system, how do they fit on Marklin tracks.
is a Bachmann engine able to cross over the switches. and holding the curbs. that where the real challenge is.
Offline dominator
#4 Posted : 05 November 2016 00:26:25(UTC)
dominator
If you can, go to a shop that sells Bachman and take a Marklin loco and some vernier calipers. Measure the dimensions of the wheels. Marklin locos run over the points on there inside flange discs, [ remember the shiny metal pieces at the bottom of the rails in the points. ] I think some systems have wheel discs which are too small. Also, some have a different distance between the disc flanges. There are other threads on this forum which have discussed this. I once bought some Lima wagons and coaches and I had to push the wheels closer together so they would no derail on the points. The guide piece adjacent to the gap in the rails, guides the opposite wheel along the rail so the inner wheel does not ride up on top of the rail and derail.
I have even had to bend the guide rail on the 5140 m track points to help marklin rolling stock negotiate the points easier.
Dereck
This page was generated in 0.268 seconds.
