Offline michelvr
#1 Posted : 12 October 2016 02:32:12(UTC)
michelvr
Good evening,
I'm trying to find information on buying a laser engraver-cutter for model making. Is anyone using one?
My purpose would be to cut styrene, balsa, basswood and plywood (3/8" 10mm). More or less to make ho scale models.
Any help in information would be appreciated.
Michel
Offline Ausipeet
#2 Posted : 12 October 2016 03:31:20(UTC)
Ausipeet
found these on eBay,
http://www.ebay.com.au/bhp/laser-cutter
other then that try Google!
thanks 1 user liked this useful post by Ausipeet
Offline GlennM
#3 Posted : 12 October 2016 10:17:20(UTC)
GlennM
#4 Posted : 13 October 2016 00:40:00(UTC)
I have a friend who is using a Laser Cutter to build Gauge 1 structures. He purchased the cutter second hand - it is a Thunder Laser Mini 60
http://www.thunderlaser.com/dow...r_manual_for_MINI-60.pdf
This is a picture of some G1 catenary masts my friend made with his cutter.
thanks 5 users liked this useful post by Bigdaddynz
Offline michelvr
#5 Posted : 13 October 2016 00:57:46(UTC)
michelvr
Quite an assortment of laser but the biggest issue is that most will not ship to Canada! Still looking.......
Michel
#6 Posted : 13 October 2016 02:19:31(UTC)
Try Aliexpress - plenty of sellers there that will ship worldwide.
https://www.aliexpress.com/whole...;SearchText=laser+cutter
Offline Drongo
#7 Posted : 04 December 2016 04:06:52(UTC)
Drongo
I've had quite a lot of experience with laser cutting acrylic, PETG, plywood and pdf board.
When I owned the company (7 years ago), I had 2 laser cutting machines - industrial standard. One was 200w & the other 500w, CO2 lasers. The smaller machine could cut through acrylic sheets up to 15mm thickness and the larger machine up to 25mm thickness. The important factor with laser cutting is to be able to adjust the focal length, i.e. the laser head must be adjustable to sit at the correct height above the material that is to be cut. Similarly, with engraving, otherwise the laser beam will not perform well. Also, fume extraction is very important when cutting acrylic, otherwise "flaming" will occur and this can be detrimental to the work as well as the machine.
Software is very important as well. Our machines had software incorporated into the machines which controlled the laser power, especially when the laser beam was changing direction. For those remember their high school calculus, when the curve changes direction there is a stationary point and the speed is zero at the point of change. Therefore, if the beam is not moving then there's extra laser power at that position and this can cause "burn outs". e.g. If you're cutting a rectangle, the the burn outs will occur at the corners.
I really miss not having the laser machines as I could really do some neat constructions. There was one item that I made and it was really successful - it was a helix cut from 3mm thick clear acrylic. The circles were cut into segments and the support columns were cut exactly to give me a 3% rise. Also, I could accurately cut pieces that were glued to the base pieces and this held the track in position.
If you need any further information, just ask.
Greg
thanks 3 users liked this useful post by Drongo
Offline Shamu
#8 Posted : 08 December 2016 07:22:54(UTC)
Shamu
From my rather limited investigations into Laser engraver/cutters you would have to be looking at around a 1W (1000mw) unit to have any hope of cutting through anything thicker than paper or thin balsa. Would I imagine be good for press out kits in thin Balsa. Fences etc.........
A 5W (5000mw) would be getting into useful territory.
Since yesterday I have been toying with getting a el-cheepo $100 1w unit just to see how it would go engraving a pattern onto hi-density foam etc. Thinking stone walls and the like.
Edited by user 10 December 2016 05:09:33(UTC)  | Reason: Not specified
This page was generated in 0.676 seconds.
