Offline Timnomads
#1 Posted : 04 October 2016 20:12:02(UTC)
Timnomads
Hi All
I want to replace the 24230 with a point into the double slip
see here
So I get this
Want I want to know is. Is the 24207 the best fit or is there another possibility.Huh
Tim
#2 Posted : 04 October 2016 20:44:49(UTC)
As the turnout is 24.3 degrees, then geometrically speaking you should be using the 24206 (5.7 degrees) not 24207 (7.5 degrees)
But that is not your real issue if you wish to maintain 77.5mm spacing to the upper right.
Assuming the goal is ALSO to achieve a 30 degree delta WITH parallelism and alignment ...
The following is ONE possible solution ...
NOTE: If space (to the upper right) is not an issue and you wish to make the small kinks less noticable, you could retain ..
- the 172/188 instead of the 94/77
- and also use 229/236 for the offset instead of the 64/71 or 71/77
OR
From there you can "freelance/what-if" to get a bit more elegance
Edited by user 08 October 2016 07:53:56(UTC)  | Reason: 24.3
Offline Timnomads
#3 Posted : 05 October 2016 08:45:28(UTC)
Timnomads
As the turnout is 22.3 degrees, then geometrically speaking you should be using the 24206 (5.7 degrees) not 24207 (7.5 degrees)
OR
Thanks, I shall put you suggestion into action tonight and calculate which pieces I need to get.
TimBigGrin
Offline rbw993
#4 Posted : 05 October 2016 17:19:03(UTC)
rbw993
Hi Tim,
The turnout is actually 24.3 degrees of curvature. So yes it will work perfectly with the 24306 (5.7 degrees).
Roger
C Track design problem (H0-scale)
by Timnomads 25/10/2016 12:22:18(UTC)
This page was generated in 0.226 seconds.
